Component: ADC (CAL) (Misc)
| Version | 2.0 |
| Category | Misc |
ADC component
CAL - Code Abstraction Layer A low level implementation giving direct access to the analogue to digital converter peripheral.
Please click here for the component source code: FC_Comp_Source_ADC.fcfx
| GetValue | |
| Gets the Name property value | |
| Name | |
| The name of the property | |
| Disable | |
| Disables the current ADC channel Call this once sampling is complete | |
| Sample | |
| Blocking call to read a sample on the currently enabled channel | |
| Sample_Mode | |
| True to enable full-width sample (10 or 12 bits), else false for 8 bit | |
| SetValue | |
| Sets the Value for the named property | |
| Name | |
| Name of property to update | |
| Value | |
| The new value for the property | |
| GetList | |
| Name | |
