API Component.GetInstance
Revision as of 08:20, 7 June 2013 by JonnyW (talk | contribs)
<sidebar>API contents</sidebar> Gets the type-instance of the component, >= 1 is valid
Class hierarchy
Component
GetInstance
HANDLE Target
The component to read the instance from
ULONG
Returns the type-instance of the component, >= 1 is valid
A components instance is a number referring to how many occurrences of a component exist before this one, including itself. The number is 1 if the component is the first of its type to be added.
This instance number is irrespective of the depth of a component - a component of the same type as the Target is still considered even if it is embedded deep in some other components tree.
Note this call relies on a match of the components GUID, so built-in component types (such as shapes and groups) do not have an instance and it will return zero.
  • Declare a variable 'result' of type ULONG
  • Add to a calculation icon:
    result = ::Component.GetInstance(target)
