Component: Output DAC (DSP Outputs)
| Author | Matrix Ltd |
| Version | 1.2 |
| Category | DSP Outputs |
Output DAC component
Allows the values from a buffer to be passed directly to an internal DAC output.
Please click here for the component source code: FC_Comp_Source_DSP_DAC.fcfx
| OutputDACArray | |
| Outputs an array of values from the input buffer appropriatley scaled to suit the DAC. | |
| Delay | |
| Delay in microseconds between outputting each sample. | |
| ControlDAC | |
| Enable or disable the DAC output, Disabled by default. | |
| State | |
| OutputDAC | |
| Outputs a single value from the input buffer appropriatley scaled to suit the DAC. | |
