Component: Deinterlace (DSP Operators)
Revision as of 14:10, 20 January 2023 by Wiki bot (talk | contribs)
Version 1.2
Category DSP Operators
Deinterlace component
Allows multiple output buffers to be deinterlaced from a single input buffer. Useful for decoding multiple buffer channels sent via communications or storage.
Please click here for the component source code: FC_Comp_Source_DSP_Deinterlace.fcfx
DeinterlaceArray
Repeats the deinterlace function as many times as set in the data count property.
Deinterlace
Outputs a single value to each of the connected output buffers from the input buffer.
Connect To
Buffer Size 0
Buffer Type 0
Buffer Size 1
Buffer Type 1
Interlace
Number of Outputs
The number of inputs the multiplexer can switch between.
Data Count
Number of complete output packets the buffer can store. Default 1.
Input Mode
