API Panel.Position.Get
<sidebar>API contents</sidebar> Gets a handle to an object representing the components current position
HANDLE Handle
- The position or component to read from
Returns the handle to an object representing the components current position
- Add to a calculation icon:
result = ::Panel.Position.Get(handle)
Obtaining a handle to a component provides the ability to hold information about the position and coordinates of that component at the time the api is called. It is effectively creates an invisible clone of the target object. This has several uses from duplicating components through to being able to track a position of an object prior to any changes to it's parameters. A good example how this is used can be seen by looking at the source code for the example provided in the API Panel.Position.Set wiki page.
