Component: Keypad (BL0138) (BL0138) (E-blocks 2)
| Category | E-blocks 2 |
Keypad (BL0138) component
Keypad component to drive the E-blocks 2 BL0138 Keypad board. Provides twelve individual raster scanned switches.
Please click here for the component source code: FC_Comp_Source_EBlocks2_KeyPad_BL0138.fcfx
| WaitPressed | |
| Blocking call that waits for one of the keys on the keypad to be pressed. The index of the key that was pressed is passed back to the user. | |
| GetAscii | |
| Gets the ASCII value for the current keypress. If no key is pressed then the macro returns the value 255. | |
| GetString | |
| Gets the ASCII value for the current keypress and returns in the form of a string. If no key pressed then the macro returns a null string. | |
| GetNumber | |
| Gets the numeric value for the current keypress. If no key pressed then the macro returns the value 255. | |
| GetIndex | |
| Gets the index value for the current keypress. If no key pressed then the macro returns the value 255. | |
| WaitReleased | |
| Blocking call that waits for the keys on the keypad to be released. If no key is pressed then the function will return immediatley. | |
