Component: Robot Arm v2 (AllCode)
Version | 1.0 |
Category | AllCode |
Robot Arm v2 component
Drives the Matrix Robot Arm v2 hardware via the AllCode API. Allows connections via USB, Bluetooth and WIFI.
Please click here for the component source code: FC_Comp_Source_RA2_ComponentSource.fcsx
SetWIFIPort |
Sets the WIFI port number | |
Port |
Default 1245 | |
Return |
SetCalibrationLengths |
Sets the lengths of parameters A and D used as part of the kinematics calculations to get and set the angles using XYZ coordinates | |
LengthA |
LengthD |
Return |
SetMovementSpeed |
Controls the movement speed of the arm and the ramping increment | |
Speed |
Range 0-10000 default 8000 | |
Increment |
Range 0 to 5000, default 50 | |
Return |
GetPLCInputs |
Reads the inputs on the secondary grove connector used to connect to outputs from a connected PLC or other external switch. | |
Return |
SetGripper |
Sets the new position of the gripper | |
Position |
0 = Closed, 255 = Fully Open | |
Return |
GetWifiIP |
Collects the IP address of the robot arm WIFI connection. | |
Return |
GetColourSensor |
Samples and returns the RGB values read by the colour sensor | |
RGB |
Byte Array To Hold the RGB sensor values | |
Return |
SetMotor |
Sets the step position of a single motor | |
Motor |
0=A, 1=B, 2=C | |
Position |
Return |
ResetToBoot |
Resets the board into bootload mode for reprogramming. Comms port will be closed on calling this macro, | |
Return |
IsMoving |
Checks to see if the robot arm or gripper is moving. Returns 0 if the arm is not moving and 1 if the arm is still in transit. | |
Return |
SetAngle |
Sets the angle of a single motor | |
Motor |
0=A, 1=B, 2=C | |
Angle |
Range 0.0 to 359.0 | |
Return |
SetXYZ |
Moves the machine so that the end tool is in the specified XYZ position. Returns 1 if the coordinates are within range of the Arm else returns 0. | |
X |
Y |
Z |
Return |
HomeAll |
Function to automatically home all motors. Macro blocks until complete. | |
Return |
SetRelay |
Allows the vacuum relay to be switched on and off. | |
State |
Return |
SetCalibrationRadius |
Radius |
Return |
SetAngles |
Sets the angle of all motors | |
AngleA |
AngleB |
AngleC |
Return |
HomeAxis |
Function to automatically home a specific motor. Macro blocks until complete. | |
Axis |
0=A, 1=B, 2=C | |
Return |
GetAngles |
Collects the current joint angles of the motors. | |
Angles |
Float Array To Hold the step position return values | |
Return |
DisableMotors |
Disables all motors | |
Return |
StoreMotors |
Stores the specified step position into an internal none volatile memory location. | |
PositionIndex |
Range: 0 to 40 | |
PositionA |
PositionB |
PositionC |
Return |
SetCanId |
Stores the specified CAN ID into an internal none volatile memory location. | |
ID |
Return |
GetAPI |
Gets the API version number | |
Return |
SetMotors |
Sets the step position of all motors | |
PositionA |
PositionB |
PositionC |
Return |
SetCanMode |
Configures the CAN mode. | |
Mode |
0=Disabled, 1=Enabled | |
Return |
GetPosition |
Collects the current step positions of the motors. | |
Positions |
UINT Array To Hold the step position return values | |
Return |
StoreCurrentPosition |
Stores the current position into an internal none volatile memory location. | |
PositionIndex |
Range: 0 to 40 | |
Return |
GetXYZ |
Collects the current XYZ position of the end tool. | |
XYZ |
INT Array To Hold the X, Y and Z return values | |
Return |
SetBluetoothMode |
Configures the Bluetooth mode. | |
Mode |
Return |
Initialise |
Return |
