Component: API (RPI) (API Slave Devices)
| Version | 2.0 |
API (RPI) component
Connects to a Raspberry Pi running the API Firmware allowing the board to become a slave to the Flowcode Embedded simulation or Flowcode App Developer. Supports: Digital IO / I2C / SPI / PWM / UART See Flowcode Help Wiki for firmware.
Please click here for the component source code: FC_Comp_Source_RPI_API_Comp.fcfx
The App Developer (RaspberryPi) component allows an Raspberry Pi to be controlled from within the Flowcode simulation runtime.
To allow Flowcode to communicate and control the Raspberry Pi hardware the board must first be pre-programmed with dedicated firmware.
The firmware file and Flowcode source project can be downloaded from here.
The IP Address to the Raspberry Pi hardware is selected via the SCADA_RPI component IP Address property.
When building the component into a App Developer project remember to expose the IP Address property to allow the end user to select the correct address for the hardware.
- fixed statistics showing IO / ADC inputs / PWM
- scrolling log showing all commands and returns
Pin Mapping
| App Developer Slave Digital Pin | 2 | 3 | 4 | 5 | 6 | 7 | 8 | 9 | 10 | 11 | 12 | 13 | 14 | 15 | 16 | 17 | 18 | 19 | 20 | 21 | 22 | 23 | 24 | 25 | 26 | 27 |
| Device Port Pin | G2 | G3 | G4 | G5 | G6 | G7 | G8 | G9 | G10 | G11 | G12 | G13 | G14 | G15 | G16 | G17 | G18 | G19 | G20 | G21 | G22 | G23 | G24 | G25 | G26 | G27 |
| App Developer Slave Peripheral Pin | I2C SDA | I2C SCL | SPI MOSI | SPI MISO | SPI SCK | UART RX | UART TX | PWM 0 | PWM 1 |
| Device Port Pin | G2 | G3 | G10 | G9 | G11 | G15 | G14 | G12 | G13 |
| I2CInitialise | |
| Initialsie the I2C module ready for communications | |
| Channel | |
| Baud | |
| IOGetInputPin | |
| Pin | |
| Range: 0-29 | |
| ADCSample8 | |
| Reads the voltage present on an Alanog pin as an 8-bit value range 0-255 | |
| ADCChannel | |
| Range: 0-12 | |
| UARTInitialise | |
| Channel | |
| UARTCheckRX | |
| Channel | |
| I2CRestart | |
| Put the I2C Module into Restart mode | |
| Channel | |
| PWMDisable | |
| Disable a PWM output | |
| Channel | |
| Range: 0-1 | |
| I2CStart | |
| Put the I2C Module into Start mode | |
| Channel | |
| SPITransfer | |
| Transfer a byte using the SPI bus | |
| Channel | |
| DataOut | |
| I2CReceive | |
| Receive a byte using the I2C bus | |
| Channel | |
| Last | |
| I2CStop | |
| Put the I2C Module into Stop mode | |
| Channel | |
| SPIPrescaler | |
| Modify the speed of the SPI bus | |
| Channel | |
| Prescaler | |
| Range: 0-2 | |
| PWMSetDuty | |
| Sets the duty for the PWM output | |
| Channel | |
| Range: 0-5 | |
| Duty | |
| ADCSample10 | |
| Reads the voltage present on an Alanog pin as an 10-bit value range 0-1023 | |
| ADCChannel | |
| Range: 0-12 | |
| IOSetOutputPin | |
| Pin | |
| Range: 0-29 | |
| State | |
| Range: 0-1 | |
| UARTReceive | |
| Channel | |
| SPIInitialise | |
| Channel | |
| I2CSend | |
| Channel | |
| DataOut | |
| UARTSend | |
| Channel | |
| Data | |
| PWMSetPrescaler | |
| Sets the prescaler for the PWM output | |
| Channel | |
| Prescaler | |
| Period | |
| PWMEnable | |
| Enable a PWM output | |
| Channel | |
| Range: 0-1 | |
