| Author
Matrix
| Version
1.0
| Category
Scenarios
CNC Machine component
A CNC Machine that allows for simulation movement in the X, Y, Z directions and also providing access to the Drill.
Please click here to view the component source code (Beta): FC_Comp_Source_CNCComponent_v002.fcfx
ZAxisMovement
| Moves the components Z axis by 0.01mm. Direction determines direction 1= Down 0 = Up If collision is detected then movement will stop and the return value will be 1. Otherwise the return value will be 0.
- BYTE
Direction
| Assign a value of 1 or 0. 1 will move the component down. 0 will move it up.
- BYTE
Drill_Speed
| Will cause the drill to rotate according to the speed. If no speed is set it will stay static.
- FLOAT
DrillSpeed
| Speed of the Drill. 0=Stopped
MoveToXYZ
| Moves the tool on the machine to the absolute X Y Z position specified at the speed specified by performing 3D linear interolation.
- FLOAT
X
- FLOAT
Y
- FLOAT
Z
YAxisMovement
| Moves the components Y axis by 0.01mm. Direction determines direction 1= Forward, 0 = Backward If collision is detected then movement will stop and the return value will be 1. Otherwise the return value will be 0.
- BYTE
Direction
| Assign a value of 1 or 0. 1 will move the component right. 0 will move it left.
- BYTE
HomeMachine
| Moves the machine an axis at a time until the end stop is hit. Finishes by resetting the coordinates to 0,0,0.
XAxisMovement
| Moves the components X axis by 0.01mm. Direction determines direction 1= Forward, 0 = Backward If collision is detected then movement will stop and the return value will be 1. Otherwise the return value will be 0.
- BYTE
Direction
| Assign a value of 1 or 0. 1 will move the component forward. 0 will move it up.
- BYTE
ResetCoordinates
| Resets the coordinates to the home position 0,0,0.
| Enables the three motors within the component allowing for movement when any of the Axis macros are called.
ZAxisMovement
- BYTE
Direction
- BYTE
Drill_Speed
- FLOAT
DrillSpeed
MoveToXYZ
- FLOAT
X
- FLOAT
Y
- FLOAT
Z
YAxisMovement
- BYTE
Direction
- BYTE
HomeMachine
XAxisMovement
- BYTE
Direction
- BYTE
ResetCoordinates
