| Author
Matrix TSL
| Version
1.0
| Category
Audio Output
DFPlayer (MP3 / WAV) component
A small module capable of streaming MP3 and WAV audio files from a micro SD card. Controlled via a serial UART connection to the microcontroller.
Please click here to view the component source code (Beta): FC_Comp_Source_DFPlayer.fcfx
No Examples here yet
PausePlayResetStop
| Allows the current playing track to be paused, restarted or reset
  - UINT
Mode
| 0=Pause, 1=Play, 2=Reset, 3=Stop
SendCommand
| Sends a command to the DFPlayer module
  - BYTE
Command
| Command code byte
  - BOOL
Feedback
| Collect feedback byte: Range 0-1
  - UINT
Parameter
| 16-bit Parameter
IsReplyAvailable
| Checks to see if new data has been received from the module. Returns true when new data is available. Collect the data using the GetReplyByte macro.
  - BOOL
SetVolume
| Sets the volume level for the module
  - BYTE
Volume
| Range: 0 (min) - 30 (max)
SetEQ
| Sets the equaliser mode for the module
  - BYTE
EQMode
| Range: 0-5 0=Normal, 1=Pop, 2=Rock, 3=Jazz, 4=Classic, 5=Bass
GetError
| Checks for any errors and returns the error code. 1=ModuleBusy, 2=SleepMode, 3=SerialError, 4=ChecksumError, 5=TrackOutOfScope, 6=TrackNotFound, 7=InsertionError, 8=SDFail, 10=Sleep
  - BYTE
WhilePlaying
| Blocking function that waits for module to stop being busy. Returns true if the module is still busy and the timeout period has passed.
  - UINT
Timeout
| Number of milliseconds to wait, 0=WaitForever
  - BOOL
IsPlaying
| Checks to see if the last played track is still playing
  - BOOL
GetReplyByte
| Reads a single byte from the last reply. Each reply contains 4 bytes starting with the command code.
  - BYTE
Index
| Range: 0-3 / 0=Command, 1=Feedback, 2=Data MSB, 3=Data LSB
  - BYTE
SkipTrack
| Jump to the next or previous track
  - BOOL
Direction
| 0=Next, 1=Previous
PlayTrack
| Plays track from the selected folder. MP3 & Advert folder track numbers should be 4 characters long e.g. 0001 any name.mp3, Other folder track numbers should be 3 characters long e.g. 001 Any name.mp3, Root the Track played in placement order.
  - BYTE
Directory
| 0=Root, 1=Folder "01" - 99=Folder "99", 100=MP3, 101=Advert
  - UINT
Track
| Track number 1="001*.MP3" / "0001*.MP3", 100="100*.MP3" / "0100*.MP3"
| Sets up the UART and does some housekeeping. Must be called before calling any of the other component macros.
| UART Channel selector Software channels are bit banged using generic I/O pins but are not as reliable as hardware channels. Hardware channels use the selected peripheral on-board the target microcontroller.
Baud Options
| Baud rate option selector
TX
| Pin to be used for Transmit data
RX
| Pin to be used for Receive data
Use Busy Pin
| Controls if we are monitoring the busy pin or not. Used by the IfBusy component macro.
| Selects if the scope traces are automatically added to the data recorder window or not.     Simulation - draws an approximation of the UART data onto the scope trace.     ICT - sets up the scope trace for incoming data and adds UART packet decoding at the correct BAUD.
Console Format
| Controls if the data is shown as a log with time and date stamps or just as raw data
Console Columns
| Number of characters that can be displayed on a single line of the console.
Data Source
| Simulation data source used to allow the component to connect to various remote devices     Nothing - Simulation data is ignored     COM port - Routes the communication data to and from a physical or virtual COM port      API - Routes the communication data via a data API component on the Panel.
API
| Selects which API component to route the communication data via. Add API components to the panel before they will be available in this list. API components are available from the Comms component category.
PausePlayResetStop
  - UINT
Mode
SendCommand
  - BYTE
Command
| Command code byte
  - BOOL
Feedback
  - UINT
Parameter
| 16-bit Parameter
IsReplyAvailable
  - BOOL
SetVolume
  - BYTE
Volume
SetEQ
  - BYTE
EQMode
GetError
  - BYTE
WhilePlaying
  - UINT
Timeout
  - BOOL
IsPlaying
  - BOOL
GetReplyByte
  - BYTE
Index
  - BYTE
SkipTrack
  - BOOL
Direction
| 0=Next, 1=Previous
PlayTrack
  - BYTE
Directory
  - UINT
Track
Baud Options
TX
RX
Use Busy Pin
Console Format
Console Columns
Data Source
API
