Component: Bluetooth (BL0170) (E-blocks 2)
Jump to navigationJump to search| Author | Matrix Ltd. |
| Version | 1.3 |
| Category | E-blocks 2 |
Bluetooth component
Low level routines for controlling a Microchip RN4677 Bluetooth Module. Also available in the form of the BL0170 Bluetooth E-block. Uses an interrupt to receive characters from the UART and improve reliability, Must be used with a hardware UART channel.
Please click here to view the component source code (Beta): FC_Comp_Source_EBlocks2_Bluetooth_RN4677_BL0170.fcfx
|   | SendString |
| Sends a string to the Bluetooth module. | |
|  - STRING | Command |
|  - BYTE | SendCR |
|  - VOID | Return |
|   | LeaveCommandMode |
| Leaves command mode allowing data to be passed back and forth, | |
|  - VOID | Return |
|   | ConnectToMAC |
| Connects to a specific Bluetooth MAC address. Waits up to 5 seconds for connection to be established. Returns 1 if connection was successful. | |
|  - STRING | MACAddress |
|  - BOOL | Return |
|   | ReceiveCount |
| Returns the number of bytes currently sat waiting in the receive buffer. | |
|  - UINT | Return |
|   | ReadString |
| Copies the incoming data from the data string array to a local string variable. | |
|  - BYTE | NumBytes |
| Maximum number of bytes to try and read | |
|  - STRING | Return |
|   | SendByte |
| Sends a single data byte out to the Bluetooth module. | |
|  - BYTE | Data |
|  - VOID | Return |
|   | EnterCommandMode |
| Enters command mode allowing commands to be sent using the SendCommand macro. Returns: 0 = No Reply / 1 = Command Mode OK | |
|  - BOOL | Return |
|   | GetMACAddress |
| Gets the local Bluetooth device MAC address. | |
|  - STRING | Return |
|   | Initialise |
| Sets up the Bluetooth module including: - Enabling the UART - Configuring the module (Name / Key / etc) Returns 1 for OK and 0 for no reply. | |
|  - BYTE | Return |
|   | SendString |
|  - BYTE | SendCR |
|  - VOID | Return |
|   | LeaveCommandMode |
|  - VOID | Return |
|   | ConnectToMAC |
|  - BOOL | Return |
|   | ReceiveCount |
|  - UINT | Return |
|   | ReadString |
|  - BYTE | NumBytes |
|  - STRING | Return |
|   | SendByte |
|  - BYTE | Data |
|  - VOID | Return |
|   | EnterCommandMode |
|  - BOOL | Return |
|   | GetMACAddress |
|  - STRING | Return |
|   | Initialise |
|  - BYTE | Return |
