| Author
Matrix TSL
| Version
1.0
| Category
E-blocks 2
GLCD Monochrome component
Graphical display component designed to work with the EB2 BL0139 Downstream E-block.
Please click here to view the component source code (Beta): FC_Comp_Source_EBlocks2_Mono_GLCD_BL0139.fcfx
ReadFontWidth
  - BYTE
Font
  - BYTE
Character
  - BYTE
SetFontScaler
  - BYTE
ScaleX
  - BYTE
ScaleY
  - INT
Number
  - UINT
X
  - UINT
Y
  - BYTE
Font
  - BYTE
Transparent
DrawLine
  - BYTE
X1
  - BYTE
Y1
  - BYTE
X2
  - BYTE
Y2
Write_Data
  - BYTE
data
DrawEllipse
  - UINT
X
  - UINT
Y
  - UINT
XRadius
  - UINT
YRadius
  - BYTE
Transparent
  - BYTE
Solid
Goto_XY
  - BYTE
X
  - BYTE
Y
Plot
  - BYTE
X1
  - BYTE
Y1
SetDisplayOrientation
  - BYTE
Orientation
BPlot
  - BYTE
X1
  - BYTE
Y1
ReadFontStat
  - BYTE
Font
  - BYTE
Index
| 0=SpaceWidth, 1=PixelHeight
  - BYTE
Print
  - STRING
Str
  - UINT
X1
  - UINT
Y1
  - BYTE
Font
  - BYTE
Transparent
ClearDisplay
SetBackgroundColour
| Specifies the colour of the foreground
  - BYTE
PixelColour
| 0=White, 1=Black
DrawCircle
  - UINT
X
  - UINT
Y
  - UINT
Radius
  - BYTE
Transparent
  - BYTE
Solid
Write_Command
  - BYTE
Command
SetForegroundColour
| Specifies the colour of the foreground.
  - BYTE
PixelColour
| 0=White, 1=Black
DrawRectangle
  - BYTE
X1
  - BYTE
Y1
  - BYTE
X2
  - BYTE
Y2
  - BYTE
Transparent
  - BYTE
Solid
Version
Dimensions
Pixel Height
Pixel Width
Colour
Monochrome
Foreground Color
Background Color
Bit Depth
Color Bit Depth
| Number of bits of colour depth available on the display
Red Bit Depth
| Number of bits of Red colour depth on the display
Green Bit Depth
| Number of bits of Green colour depth on the display
Blue Bit Depth
| Number of bits of Blue colour depth on the display
CS
| Chip select pin
Reset
A0
| Address pin to tell the display if we are sending commands or data
Data Pin
Clock Pin
Fonts
Font Count
Font 0
Font
Character Spacing
Space Width
Display Method
Component Label
Component Label Scale
ReadFontWidth
  - BYTE
Font
  - BYTE
Character
  - BYTE
SetFontScaler
  - BYTE
ScaleX
  - BYTE
ScaleY
  - INT
Number
  - UINT
X
  - UINT
Y
  - BYTE
Font
  - BYTE
Transparent
DrawLine
  - BYTE
X1
  - BYTE
Y1
  - BYTE
X2
  - BYTE
Y2
Write_Data
  - BYTE
data
DrawEllipse
  - UINT
X
  - UINT
Y
  - UINT
XRadius
  - UINT
YRadius
  - BYTE
Transparent
  - BYTE
Solid
Goto_XY
  - BYTE
X
  - BYTE
Y
Plot
  - BYTE
X1
  - BYTE
Y1
  - BYTE
Orientation
BPlot
  - BYTE
X1
  - BYTE
Y1
ReadFontStat
  - BYTE
Font
  - BYTE
Index
  - BYTE
Print
  - STRING
Str
  - UINT
X1
  - UINT
Y1
  - BYTE
Font
  - BYTE
Transparent
ClearDisplay
SetBackgroundColour
  - BYTE
PixelColour
| 0=White, 1=Black
DrawCircle
  - UINT
X
  - UINT
Y
  - UINT
Radius
  - BYTE
Transparent
  - BYTE
Solid
Write_Command
  - BYTE
Command
SetForegroundColour
  - BYTE
PixelColour
| 0=White, 1=Black
DrawRectangle
  - BYTE
X1
  - BYTE
Y1
  - BYTE
X2
  - BYTE
Y2
  - BYTE
Transparent
  - BYTE
Solid
Version
Dimensions
Pixel Height
Pixel Width
Colour
Monochrome
Foreground Color
Background Color
Bit Depth
Color Bit Depth
Red Bit Depth
Green Bit Depth
Blue Bit Depth
CS
| Chip select pin
Reset
A0
Data Pin
Clock Pin
Fonts
Font Count
Font 0
Font
Character Spacing
Space Width
Display Method
Component Label
