Component: EEPROM (DS28E07) (EEPROM)
Revision as of 15:14, 20 January 2023 by Wiki bot (talk | contribs)
Author MatrixTSL
Category EEPROM
EEPROM (DS28E07) component
A rugged EEPROM allowing one or more devices to be addressed and accessed. Requires a One Wire component to perform the bus operations.
Please click here to view the component source code (Beta): FC_Comp_Source_EEPROM_DS28E07.fcfx
SetString
Writes a string to the EE memory starting at the selected address. All bytes from the string will be written including the null termination.
- UINT Address
Address of the value to write
- STRING Value
Data string to write
GetString
Gets a string from the specified start address.
- UINT Address
Address of the first data byte
- BYTE MaxLength
Maximum number of bytes in the string, also includes null termination byte
- STRING Return
SetByteArray
Writes an array of bytes to the EE memory.
- UINT Address
Starting address of the first value to write
- BYTE Data
- BYTE Count
Number of bytes to write to the EE memory, Range: 1 to 128 bytes
SetInt
Writes a 16-bit value to the EE memory. For consecutive 16-bit values the address must be incremented by 2.
- UINT Address
- UINT Value
16-bit value to write
- BOOL MSBFirst
0: LSB is the first byte, 1: MSB is the first byte
AddressSpecificDevice
Starts a temperature conversion on a specific device using a hex string identifier. SerialNumber parameter should be 12 characters and contain the 48-bit Serial.
- STRING SerialNumber
48-bit Serial Number e.g. "32DF4A3C1901"
GetSerialString
Gets the Serial String for the current addressed device.
- STRING Return
AddressNextDevice
Scans for the next connected device with a matching family code. Goes through the device list generated by the ScanBus macro.
SetLong
Writes a 32-bit value to the EE memory. For consecutive 32-bit values the address must be incremented by 4.
- UINT Address
- ULONG Value
32-bit value to write
- BOOL MSBFirst
GetFloat
Reads a 32-bit floating point value starting from the specified byte address. For consecutive float values the address must be incremented by 4.
- INT Address
The starting byte address
- BOOL MSBFirst
- FLOAT Return
GetLong
Reads a 32-bit value starting from the specified byte address. For consecutive 32-bit values the address must be incremented by 4.
- INT Address
- BOOL MSBFirst
- ULONG Return
GetInt
Reads a 16-bit value starting from the specified byte address. For consecutive 16-bit values the address must be incremented by 2.
- INT Address
- BOOL MSBFirst
GetByteArray
Reads an array of bytes starting from the selected address.
- UINT Address
Starting address of the first value to read
- BYTE Data
Byte array to store incoming data
- UINT Count
Number of bytes to read from the EE memory, Range: 1 to 128 bytes
SetByte
Writes a single byte to the EE memory.
- UINT Address
- BYTE Data
GetByte
Reads a single byte from the selected address.
- UINT Address
Address of the value to read
SetFloat
Writes a 32-bit floating point value to the EE memory. For consecutive float values the address must be incremented by 4.
- UINT Address
- FLOAT Value
Floating point value to write
- BOOL MSBFirst
Configures each matching sensor on the bus with the specified conversion bits.
One Wire Component
Link to the one wire component to host the bus.
EEPROM Size (Bytes)
Simulate Comms
No - We use the panel GUI to perform the simulation. Yes - We use OneWire comms via an API to communicate with real hardware.
Panel Simulation
Number EE Devices
Sens the number of sensors we can communicate with during simulation
Serial 0
Serial number for simulated one wire device
SetString
- UINT Address
- STRING Value
GetString
- UINT Address
- BYTE MaxLength
- STRING Return
SetByteArray
- UINT Address
- BYTE Data
- BYTE Count
SetInt
- UINT Address
- UINT Value
- BOOL MSBFirst
GetSerialString
- STRING Return
AddressNextDevice
SetLong
- UINT Address
- ULONG Value
- BOOL MSBFirst
GetFloat
- INT Address
- BOOL MSBFirst
- FLOAT Return
GetLong
- INT Address
- BOOL MSBFirst
- ULONG Return
GetInt
- INT Address
- BOOL MSBFirst
GetByteArray
- UINT Address
- BYTE Data
- UINT Count
SetByte
- UINT Address
- BYTE Data
GetByte
- UINT Address
SetFloat
- UINT Address
- FLOAT Value
- BOOL MSBFirst
One Wire Component
EEPROM Size (Bytes)
Simulate Comms
Panel Simulation
Number EE Devices
Serial 0
