Component: Quadrature Encoder 2D (General Input)
| Version | 1.4 |
| Category | General Input |
Quadrature Encoder 2D component
Quadrature Encoder component implements a rotary encoder connected to two pins. Quadrature Encoders provides incremental positioning rather than absolute positioning.
Please click here to view the component source code (Beta): FC_Comp_Source_Encoder_Quadrature_2dgi.fcfx
| CheckForChanges | |
| Polling function to check changes Returns 1 for chaged, 0 for no change, 255 for error | |
| Disable | |
| Disables the use of the quad encoder Once this ist called, the read functions will return zeros until the next Enable() call | |
| WriteCounter32 | |
| Sets the value of the internal count variable. Range: -2147483648 to 2147483647 | |
| Value | |
| Enable | |
| Enables the use of the quad encoder If this is not called, the read functions will return zeros | |
| ReadCounter | |
| Reads the current dial counter This is a counter from -32768 to 32767 | |
| WriteCounter | |
| Sets the value of the internal count variable. Range: -32768 to 32767 | |
| Value | |
| ResetCounter | |
| Resets the current dial counter to zero | |
| ReadCounter32 | |
| Reads the current dial counter as a 32-bit value This is a counter from -2147483648 to 2147483647 | |
| CheckForChanges | |
| Disable | |
| WriteCounter32 | |
| Value | |
| Enable | |
| ReadCounter | |
| WriteCounter | |
| Value | |
| ResetCounter | |
| ReadCounter32 | |
