Component: Injector (API Digital Output) (Test Injectors)
| Author | Matrix Ltd |
| Version | 1.2 |
| Category | Test Injectors |
Injector (API Digital Output) component
Data injector to allow a physical digital output pin to be attached to a simulated component. The component will forward any output state changes through to a SCADA Slave enabled hardware. Enabling the Flowcode simulation runtime to directly interface with a physical I/O pin.
Please click here to view the component source code (Beta): FC_Comp_Source_InjectorSCADADigitalOutput.fcfx
| InitialiseInjector | |
| Sets up the injector ready to receive commands or send data | |
| InjectorName | |
| Name of the console that will be created | |
| RxByteCount | |
| Returns the number of bytes currently sat in the receive buffer. | |
| TxByte | |
| Puts a byte onto the comms channel. | |
| DataByte | |
| RxByte | |
| Attempt to receive a byte back from the injector 0 - 255 = Valid data 256 = RX timeout no data available | |
| GetConsoleHandle | |
| Gets the handle to the console allowing data displaying on the panel etc. | |
| InjectorName | |
| RxByteCount | |
| TxByte | |
| DataByte | |
| RxByte | |
