Component: Simulation External Input (Runtime Tools)
Revision as of 15:17, 20 January 2023 by Wiki bot (talk | contribs)
Version 1.1
Category Runtime Tools
Simulation External Input component
A simulation only component designed to allow a single digital pin to be toggled at a set frequency. Allows things like switch presses or external square waves to be used with the simulation.
Please click here to view the component source code (Beta): FC_Comp_Source_Sim_External_Input.fcfx
Control_Pulse
Controls if the toggle input is enabled or disabled allowing you to stop and start the waveform.
- BYTE State
0=Disabled, 1=Enabled
Get_Pulse_Count
Reads the number of pulses remaining in the current run. The Pulse Count property needs to have an initial value > 0 to switch on the pulse counting mode.
- ULONG Return
Set_Space
Overrides the component property setting allowing for a variable frequency input or adjustable Space timings.
- UINT Delay
Delay between transitiions in milliseconds.
Set_Pulse_Count
Overrides the number of pulses. The Pulse Count property needs to have an initial value > 0 to switch on the pulse counting mode.
- ULONG PulseCount
Number of pulses to output
Set_Frequency
Allows the frequency to be changed on the fly
- FLOAT Frequency
Set_Mark
Overrides the component property setting allowing for a variable frequency input or adjustable Mark timings.
- UINT Delay
Pin
Pin to toggle - connected to the external waveform on the target hardware.
Startup Mode
Controls if the pulses start when the simulation is started or when the simulation Control_Pulse macro is called.
Mode
Frequency (Hz)
Frequency to try and acheive.
Period Delay (ms)
Delay in milliseconds for a whole period of 0 and 1.
Mark Delay (ms)
Delay in milliseconds to wait to toggle the pin. Note that Windows can only acheive timings of 10ms or more.
Space Delay (ms)
Pulse Count
Number of pulses to output. 0 = Run forever. > 0 = Output the selected number of pulses
Control_Pulse
- BYTE State
Get_Pulse_Count
- ULONG Return
Set_Space
- UINT Delay
Set_Pulse_Count
- ULONG PulseCount
Set_Frequency
- FLOAT Frequency
Set_Mark
- UINT Delay
Pin
Startup Mode
Mode
Frequency (Hz)
Period Delay (ms)
Mark Delay (ms)
Space Delay (ms)
Pulse Count
