| Author
Matrix Ltd.
| Version
1.5
| Category
Wireless
Zigbee (EB051, XBEE) component
Zigbee component designed to work with the XBEE range of modules from Digi. Provides a very simple interface to allow Zigbee mesh networks and communications. Also available in the form of the EB051 Zigbee E-block. Can also be used with Zigbee MIAC Addon module
Please click here to view the component source code (Beta): FC_Comp_Source_Zigbee.fcfx
NodeConfigureSleep
| Sets the Zigbee device sleep mode (only applicable for end node type devices) ,
  - BYTE
Mode
| 1=Hibernate, 2=Doze, 4=Cyclic Sleep, 5=Cyclic Doze
  - UINT
Timeout
| Time to sleep in milli seconds (ms)
ReadNameFromBuffer
| Returns a byte from the 8-Byte name
  - BYTE
Device
| The Device name to collect. Range: 0-7
  - BYTE
Idx
| The index position of the name. Range: 0-7
  - BYTE
NodeWake
| Wakes up the local Zigbee module from sleep mode.
ReadATResponse
| Reads a single byte from the received AT command response.
  - BYTE
idx
| Specified the byte index in the buffer. Range 0-15
  - BYTE
ScanBuffer
| Returns a binary list of matched identifier names
  - STRING
Compare_Str
  - BYTE
Length
  - BYTE
SendChar
| Transmits a byte value to the Zigbee module.
  - BYTE
Byte
| Data byte to transmit. Range 0-255
InitNetwork
| Initialises the Zigbee module and attempts to setup or join the network
ConnectToCoordinator
| Attempts to connect the data channel to the network coordinator node.
  - BYTE
MIAC_Module_GetData
  - BYTE
Index
  - BYTE
ConnectToName
| Attempts to connect the data channel to a named device on the network.
  - STRING
Name
  - BYTE
StoreParams
| Stores the current register set into the Zigbee module's non volatile memory
EnterCommandMode
| Moves from data mode into command mode by sending the special characters
RestartNetwork
| Attempts to restart the network
MIAC_Module_Message
  - UINT
CAN_ID
  - UINT
CMD_ID
  - BYTE
ConnectToAll
| Attempts to connect the data channel to all devices on the network.
  - BYTE
ConnectFromLibrary
| Attempts to connect the data channel to a known device on the network.
  - BYTE
Mode
  - BYTE
Device
  - BYTE
ConnectToAddress
| Attempts to connect the data channel to a specific device address on the network.
  - STRING
Address
  - BYTE
GetSignalLevel
| Returns the signal strength of the last signal received
  - BYTE
ExitCommandMode
| Returns from command mode to allow data to be sent and received
MIAC_Module_PushData
  - BYTE
Data
ReadAddressFromBuffer
| Reads a byte from a 16-bit Zigbee device address
  - BYTE
Device
  - BYTE
Idx
  - BYTE
SendATCommand
| Transmits a string of values to the Zigbee module.
  - STRING
Command
| Transmits a command to the Zigbee module followed by a carriage return
ScanNetwork
| Scans the local network for devices and stores into a local device array. Mode = 0 store device names, mode = 1 store device addresses. Returns the number of devices found.
  - BYTE
Mode
  - BYTE
GetATResponse
| Waits for a response from the Zigbee module. If the Logging parameter is set then the response is stored in memory allowing the software to read the reply.
  - BYTE
Logging
  - BYTE
ReceiveChar
| Attempt to receive a byte from the Zigbee module.
  - BYTE
nTimeout
  - BYTE
Device Name
| String of characters used to allow the Zigbee node to use the name addressing mode of operation.  Can be left blank if name addressing is not being used.
Zigbee Mode
| Specifies the functionality of the Zigbee node. Coordinator - Must be used with a Coordinator Zigbee E-Block EB051C, Responsible for starting the network and assigning addresses. Router - Must be used with a Router / End Node E-Block EB051R, Responsible for forwarding / repeating packets on the network. End Device - Must be used with a Router / End Node E-Block EB051R, Capable of low power operation.
Auto ID
| Automatically generate a PAN ID
PAN ID
| Assigns a Personal Area Network Identifier code to the Zigbee node. Random / Search - Scans the local area for Zigbee PAN networks and joins the existing network, otherwise a random value is chosen. Preset - Assigns a preset PAN ID to the Zigbee node, Must be between 0x0 and 0x3FFF.
Node Join Time
| Length of time in seconds where nodes are allowed to join the network. Infinte - Nodes are always allowed to join the network. Preset - Nodes are only allowed to join the network for a specific amount of time. Note: Join time not available for End Device nodes.
Max Hops
| Specifies the maximum number of retransmits for a Broadcast transmission.
Sleep Buffer Time
| Length of time to buffer packets for sleeping or powered down nodes. This value must be consistent throughout the Zigbee network. Default - Assigns the maximum buffer time of 28 seconds. Preset - Allows for a custom sleep time of 0.32 - 28 seconds.
| UART Channel selector Software channels are bit banged using generic I/O pins but are not as reliable as hardware channels. Hardware channels use the selected peripheral on-board the target microcontroller.
TX
| Pin to be used for Transmit data
RX
| Pin to be used for Receive data
Baud Options
| Baud rate option selector
Use Flow Control
| Flow Control (Handshake) enable or disable.     On: Two I/O pins are used to control the flow of data in and out of the device.     Off: Flow control is disabled.
RTS
| Pin to be used for Request To Send handshake function Output from target micro to inform remote device we are ready to receive data. Low = Ready to receive data High = Not ready to receive data
CTS
| Pin to be used for Clear To Send handshake function. Input to target micro to inform when the remote device is ready to transmit data. Low = Ready to transmit data High = Not ready to transmit data
Sleep Pin
| Zigbee Sleep Control Pin
Scan Channels
0x0B
| Determines if channel will be scanned
0x0C
0x0D
0x0E
0x0F
0x10
0x11
0x12
0x13
0x14
0x15
0x16
0x17
0x18
0x19
0x1A
Scan Duration
| Configures the length of time to scan each channel for network activity. The overall time for the entire channel scan is shown as channel scan time.
Total Scan Time (ms)
| The total amount of time that it will take to perform a complete RF channel scan based on the selected scan channels and duration.
| Selects if the scope traces are automatically added to the data recorder window or not.     Simulation - draws an approximation of the UART data onto the scope trace.     ICT - sets up the scope trace for incoming data and adds UART packet decoding at the correct BAUD.
Console Columns
| Number of characters that can be displayed on a single line of the console.
Data Source
| Simulation data source used to allow the component to connect to various remote devices     Nothing - Simulation data is ignored     COM port - Routes the communication data to and from a physical or virtual COM port      API - Routes the communication data via a data API component on the Panel.
NodeConfigureSleep
  - BYTE
Mode
  - UINT
Timeout
ReadNameFromBuffer
  - BYTE
Device
  - BYTE
Idx
  - BYTE
NodeWake
ReadATResponse
  - BYTE
idx
  - BYTE
ScanBuffer
  - STRING
Compare_Str
  - BYTE
Length
  - BYTE
SendChar
  - BYTE
Byte
InitNetwork
  - BYTE
MIAC_Module_GetData
  - BYTE
Index
  - BYTE
ConnectToName
  - STRING
Name
  - BYTE
StoreParams
EnterCommandMode
RestartNetwork
MIAC_Module_Message
  - UINT
CAN_ID
  - UINT
CMD_ID
  - BYTE
ConnectToAll
  - BYTE
ConnectFromLibrary
  - BYTE
Mode
  - BYTE
Device
  - BYTE
ConnectToAddress
  - STRING
Address
  - BYTE
GetSignalLevel
  - BYTE
ExitCommandMode
  - BYTE
Data
  - BYTE
Device
  - BYTE
Idx
  - BYTE
SendATCommand
  - STRING
Command
ScanNetwork
  - BYTE
Mode
  - BYTE
GetATResponse
  - BYTE
Logging
  - BYTE
ReceiveChar
  - BYTE
nTimeout
  - BYTE
Device Name
Zigbee Mode
Auto ID
PAN ID
Node Join Time
Max Hops
Sleep Buffer Time
TX
RX
Baud Options
Use Flow Control
RTS
CTS
Sleep Pin
Scan Channels
0x0B
0x0C
0x0D
0x0E
0x0F
0x10
0x11
0x12
0x13
0x14
0x15
0x16
0x17
0x18
0x19
0x1A
Scan Duration
Console Columns
Data Source
