Component: Switch (Push, PCB) ()
| Author | Matrix Ltd |
| Version | 1.1 |
| Category |
Switch (Push, PCB) component
Simple tactile PCB switch for PCB mounting. Approx. 12 * 12mm. Color and operation can be set from properties.
Please click here to view the component source code (Beta): FC_Comp_Source_sw_push_pcb.fcfx
Switch
(5V / 11K) * 10K = 4.54545V
