Component: Numeric Display (Indicators)
Revision as of 15:19, 20 January 2023 by Wiki bot (talk | contribs)
Category Indicators
Numeric Display component
Allows a numeric value to be displayed on the user panel using virtual 7 seg displays. Used for displaying the value of a variable during simulation runtime. Provides up to 5 customisable ranges to automatically alter the colour of the label based on the value.
Please click here to download the component source project: FC_Comp_Source_7SegNumeric.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_7SegNumeric.fcfx
An example of a numeric display changing colour set out within the display properties
Basic Numeric Display Example
DisplayAsReal
Displays a floating point value on the label with a confiiguarable number of decimal points
- FLOAT Value
Real floating point value to display
- BYTE Precision
Number of decimal point values to show e.g. 2 = 0.00
SetBackgroundColour
Allows the user to manually specify the default colour of the background.
- LONG Colour
RGB colour in the hexadecimal form 0xBBGGRR
SetForegroundColour
Allows the user to manually specify the default colour of the foreground text.
- LONG Colour
DisplayAsInt
Displays an integer value on the label. Capable of displaying positive and negative values.
- LONG Value
Integer value to display
Title
Show Title
Decides if the title is shown on the panel.
Title Text
Specifies the title displayed on the panel.
Title Scale
Specifies the size of the title on the panel, default 1.2
Title Colour
Specifies the colour of the title text
Title Offset
Distance above component center to draw the title
Display Properties
Number of Digits
Number of digits in the indicator. The number of digits sets the range available For example 4 Digits can display 0000 to 9999, out of range items will be shown as - - - -
Colour Ranges
Allows ranges to be specified to automatically format the foreground and background colours based on the numeric value
Defaults
Foreground Colour
The label foreground Text colour
Background Colour
The label background Surrounding colour
DisplayAsReal
- FLOAT Value
- BYTE Precision
SetBackgroundColour
- LONG Colour
SetForegroundColour
- LONG Colour
DisplayAsInt
- LONG Value
Title
Show Title
Title Text
Title Scale
Title Colour
Title Offset
Display Properties
Number of Digits
Colour Ranges
Defaults
Foreground Colour
Background Colour
DisplayAsReal
- FLOAT Value
- BYTE Precision
SetBackgroundColour
- LONG Colour
SetForegroundColour
- LONG Colour
DisplayAsInt
- LONG Value
Title
Show Title
Title Text
Title Scale
Title Colour
Title Offset
Display Properties
Number of Digits
Colour Ranges
Defaults
Foreground Colour
Background Colour
