| Author
Medelec35
| Version
1.0
| Category
Environmental
Analogue Temp Sensors component
A range of the most popular temperature analogue sensors which are: AD22100, AD22103, LM135, LM235, LM335, LM34, LM35, LM60, MCP9700, MCP9701, TC1047, TMP35, TMP36, TMP37 & TSIC301. Uses a single ADC pin which will allow you to display the temperature in C or F. If your sensor is not listed, there is a Custom option. You will be able to enter the scale factor, offset voltage, Temperature Compensation, min and maximum temperatures If the temperature is outside the min and max values, then 999.9 will be displayed.
Please click here to download the component source project: FC_Comp_Source_Analogue_Temperature_Sensors.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_Analogue_Temperature_Sensors.fcfx
VoltageADC
| Calculates what the approximate voltage should be based on Vref, Scale factor, Offset. For TSIC301, based on Max temp and Min temp only.
- FLOAT
GetTempIntCX10
| Value of integer temperature in deg C x10 E.g 22.5C will give the result of 225 This allows more contol if using integers to save memory 9999 = temperature outside of sensor range
- INT
GetTempIntFX10
| Value of integer temperature in deg F x10 E.g 62.5F will give the result of 625 This allows more contol if using integers to save memory 9999 = temperature outside of sensor range
- INT
IntValueADC
| The Integer ADC value of the sensor output volttage
- INT
GetTempStringF
| String value of integer temperature in degF to one decimal place. E.g 70.2 999,9 = temperature outside of sensor range
- STRING
GetTempFloatF
| Value of the temperature in deg F 999,9 = temperature outside of sensor range
- FLOAT
GetTempStringC
| String value of integer temperature in deg C to one decimal place. E.g 22.5 999,9 = temperature outside of sensor range
- STRING
GetTempFloatC
| Value of the temperature in deg C 999.9 = temperature outside of sensor range
- FLOAT
Select Sensor
| Select the required sensor. Custom allows you to enter parameters of an analogue sensor not covered.
ADC Properties
| Analogue Input Channel - Which pin is the analogue input connected to?
Vref (mV)
| For a more accurate reading, enter the exact referance voltage.
VRef option
| Defines what is used as the ADC maximum reference. ADC Range = GND to VRef Voltage VDD - Defines the microcontrollers power supply pin as the max reference, VREF+ Pin - Dedicated pin on the microcontroller to allow for a variable reference voltage.
Conversion speed
| Clock setting to select how fast the ADC peripheral will perform an ADC conversion. The FRC setting is based on a RC time base and so will vary with temperature and pressure. Other settings are generally based on divisions of the master clock.
Acquisition cycles
| Number of micro seconds to wait for the ADC input to charge before starting the analogue sample.
Total average samples
| The number of ADC samples taken. The higher the number the more stable the reading.
Sensor Characteristics
Temp compensation x10
| Set value to compensate for sensor and other vairations. E.g. -10 = Set the temperature 1 degrees lower 5 = Set the temperature 0.5 degrees higher
Scale factor (mV x100)
| for a scale factor of 22mv/C or 22mV/F it's 2200. Scale factor is set for you automatically. It can only be adjusted when custom is selcted.
Offset (mV)
| Offset is set for you automatically. It can only be adjusted when custom is selcted.
Max Temp
| Max Temp the sensor can reach is set for you automatically. It can only be adjusted when custom is selcted.
Min Temp
Centigrade
| 0 for a fahrenheit sensor. 1 for a centigrade sensor. Can only be changed when custom is selected.
Kelvin
| 1 for a kelvin sensor. Can only be changed when custom is selected.
VoltageADC
- FLOAT
GetTempIntCX10
- INT
GetTempIntFX10
- INT
IntValueADC
- INT
GetTempStringF
- STRING
GetTempFloatF
- FLOAT
GetTempStringC
- STRING
GetTempFloatC
- FLOAT
Select Sensor
ADC Properties
Vref (mV)
VRef option
Conversion speed
Acquisition cycles
Offset (mV)
Max Temp
Min Temp
Centigrade
Kelvin
VoltageADC
- FLOAT
GetTempIntCX10
- INT
GetTempIntFX10
- INT
IntValueADC
- INT
GetTempStringF
- STRING
GetTempFloatF
- FLOAT
GetTempStringC
- STRING
GetTempFloatC
- FLOAT
Select Sensor
ADC Properties
Vref (mV)
VRef option
Conversion speed
Acquisition cycles
Offset (mV)
Max Temp
Min Temp
Centigrade
Kelvin
