Component: Base2dChart (Development)
Revision as of 15:20, 20 January 2023 by Wiki bot (talk | contribs)
Author Steve Tandy
Version 1.1
Category Development
Base2dChart component
A base component for creating 2d charts.
Please click here to download the component source project: FC_Comp_Source_Base2dChart.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_Base2dChart.fcfx
AddDataXYY1
Adds a data point for a ternary chart (3 axes) to the specified series.
- BYTE Series
Which series to add to (1-8)
- FLOAT xValue
The value on the first axis
- FLOAT yValue
The value on the second axis
- FLOAT zValue
The value on the third axis
AddData
Adds a data point (y-value only) to the specified series.
- BYTE Series
- FLOAT Value
The data point value
GetDataXY
Gets a data point from the specified XY reference
- BYTE Series
Which series to read from (1-8)
- INT X
X location of the data (1 - 32767)
- INT Y
Y location of the data (1 - 255)
- FLOAT Return
AddDataXY
Adds a data point (x and y values) to the specified series.
- BYTE Series
- FLOAT xValue
The x coordinate for the data point
- FLOAT yValue
The y coordinate for the data point
AddCatData
- BYTE Series
- STRING Category
- FLOAT Value
SetMode
Select the mode of operation
- BOOL bUseArrays
True if data points are added to a hidden buffer; False if data is drawn directly onto chart.
ClearData
Removes all datapoints from the chart.
RefreshChart
Redraws the chart.
GetData
Gets a data point from the specified series.
- BYTE Series
- INT Index
The data point index (1 - 32767)
- FLOAT Return
AddDataCXYY1
Adds a data point to a bubble chart.
- BYTE Series
- STRING Category
- FLOAT Y
Y coordinate
- FLOAT X
X coordinate
- FLOAT Value
The value of the data point
Data
Categories
Y Values
X Values
Z Values
Title
Style
Stacking
Fill Gradient
Transparency
Data Between Ticks
X-axis
Name
Show Grid
Auto-scale
Start
End
Logarithmic
Scalable
Y-axis
Name
Show Grid
Auto-scale
Start
End
Logarithmic
Scalable
Y-axis (secondary)
Name
Show Grid
Auto-scale
Start
End
Logarithmic
Scalable
Data Labels
Show
Show Category
Show Value
Show Percentage
Show Series
Angle
Position
Legend
Position
Draw Border
Select Series
Series1
Series Name
Visible
Secondary Axis
Line Style
Line Type
Line Width
Shadow
Fill
Show Marker
Marker Shape
Marker Size
AddDataXYY1
- BYTE Series
- FLOAT xValue
- FLOAT yValue
- FLOAT zValue
AddData
- BYTE Series
- FLOAT Value
GetDataXY
- BYTE Series
- INT X
- INT Y
- FLOAT Return
AddDataXY
- BYTE Series
- FLOAT xValue
- FLOAT yValue
AddCatData
- BYTE Series
- STRING Category
- FLOAT Value
SetMode
- BOOL bUseArrays
ClearData
RefreshChart
Redraws the chart.
GetData
- BYTE Series
- INT Index
- FLOAT Return
AddDataCXYY1
- BYTE Series
- STRING Category
- FLOAT Y
Y coordinate
- FLOAT X
X coordinate
- FLOAT Value
Data
Categories
Y Values
X Values
Z Values
Title
Style
Stacking
Fill Gradient
Transparency
Data Between Ticks
X-axis
Name
Show Grid
Auto-scale
Start
End
Logarithmic
Scalable
Y-axis
Name
Show Grid
Auto-scale
Start
End
Logarithmic
Scalable
Y-axis (secondary)
Name
Show Grid
Auto-scale
Start
End
Logarithmic
Scalable
Data Labels
Show
Show Category
Show Value
Show Percentage
Show Series
Angle
Position
Legend
Position
Draw Border
Select Series
Series1
Series Name
Visible
Secondary Axis
Line Style
Line Type
Line Width
Shadow
Fill
Show Marker
Marker Shape
Marker Size
AddDataXYY1
- BYTE Series
- FLOAT xValue
- FLOAT yValue
- FLOAT zValue
AddData
- BYTE Series
- FLOAT Value
GetDataXY
- BYTE Series
- INT X
- INT Y
- FLOAT Return
AddDataXY
- BYTE Series
- FLOAT xValue
- FLOAT yValue
AddCatData
- BYTE Series
- STRING Category
- FLOAT Value
SetMode
- BOOL bUseArrays
ClearData
RefreshChart
Redraws the chart.
GetData
- BYTE Series
- INT Index
- FLOAT Return
AddDataCXYY1
- BYTE Series
- STRING Category
- FLOAT Y
Y coordinate
- FLOAT X
X coordinate
- FLOAT Value
Data
Categories
Y Values
X Values
Z Values
Title
Style
Stacking
Fill Gradient
Transparency
Data Between Ticks
X-axis
Name
Show Grid
Auto-scale
Start
End
Logarithmic
Scalable
Y-axis
Name
Show Grid
Auto-scale
Start
End
Logarithmic
Scalable
Y-axis (secondary)
Name
Show Grid
Auto-scale
Start
End
Logarithmic
Scalable
Data Labels
Show
Show Category
Show Value
Show Percentage
Show Series
Angle
Position
Legend
Position
Draw Border
Select Series
Series1
Series Name
Visible
Secondary Axis
Line Style
Line Type
Line Width
Shadow
Fill
Show Marker
Marker Shape
Marker Size
