Component: Console Writer (Indicators)
Revision as of 15:20, 20 January 2023 by Wiki bot (talk | contribs)
Category Indicators
Console Writer component
A simple component to aid in creating and wiriting data to a console tab. Allows text to be coloured and automatically appended with a timestamp.
Please click here to download the component source project: FC_Comp_Source_ConsoleWriter.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_ConsoleWriter.fcfx
A basic example using two circular knobs to simulate data e.g., temperature. Both xy chart and Console, log the data.
Logging Example
Clear
Clears the contents of the console tab.
CountLines
Counts the number of lines in the console.
- ULONG Return
AddString
Adds text string to the console window.
- STRING Data
SetTextLine
Sets the string data from a specific line in the console.
- LONG Line
Line number, -1 for the last line.
- STRING Data
SetColour
Allows for full RGB colour selection
- BYTE R
Colour channel, Range: 0-255
- BYTE G
- BYTE B
SetColourIdx
Sets the text colour from the properties selection of colours.
- BYTE Index
Range: 0-3
ShowConsole
Pops up the console window and shows the correct tab.
GetTextLine
Gets the string data from a specific line in the console.
- LONG Line
- STRING Return
Console Name
Textual name of the console shown as the tab name at the top of the console window.
Colour 0
Used to define a colour channel referenced by the SetColourIdx component macro call.
Colour 1
Colour 2
Colour 3
New Line After Data
Automatically append a newline character after any data has been written to the console using the AddString component macro.
Clear On Sim Start
Automatically clear the console tab when the simulation is started.
Add Timestamp
Automatically adds a timestamp to the console after a newline character has been received.
Timestamp
Date Format
Specifies the format of the date string. No - "DD/MM/YY" Yes - "MM/DD/YY"
Time Separator
Characters that are used in between the time digits
Date Separator
Characters that are used in between the date digits
TimeStamp Separator
Characters that are used between the time and date strings when returning a full time stamp.
Override Colour
Overrides the current selected colour when writing the timestamp.
Timestamp Colour
Defines the colour of the time stamp text
Clear
CountLines
- ULONG Return
AddString
- STRING Data
SetTextLine
- LONG Line
- STRING Data
SetColour
- BYTE R
- BYTE G
- BYTE B
SetColourIdx
- BYTE Index
Range: 0-3
ShowConsole
GetTextLine
- LONG Line
- STRING Return
Console Name
Colour 0
Colour 1
Colour 2
Colour 3
New Line After Data
Clear On Sim Start
Add Timestamp
Timestamp
Date Format
Time Separator
Date Separator
TimeStamp Separator
Override Colour
Timestamp Colour
Clear
CountLines
- ULONG Return
AddString
- STRING Data
SetTextLine
- LONG Line
- STRING Data
SetColour
- BYTE R
- BYTE G
- BYTE B
SetColourIdx
- BYTE Index
Range: 0-3
ShowConsole
GetTextLine
- LONG Line
- STRING Return
Console Name
Colour 0
Colour 1
Colour 2
Colour 3
New Line After Data
Clear On Sim Start
Add Timestamp
Timestamp
Date Format
Time Separator
Date Separator
TimeStamp Separator
Override Colour
Timestamp Colour
