Component: Data Transfer (API I2C) ()
Revision as of 15:22, 20 January 2023 by Wiki bot (talk | contribs)
Version 1.2
Category
Data Transfer (API I2C) component
Comms data injector to allow a I2C bus peripheral to be attached to a comms component. The component will forward any byte transactions through to a SCADA Slave enabled hardware. Enabling the Flowcode simulation runtime to directly drive a physical I2C bus.
Please click here to download the component source project: FC_Comp_Source_InjectorSCADAI2C.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_InjectorSCADAI2C.fcfx
InitialiseInjector
- STRING InjectorName
TxByte
- BYTE DataByte
RxByte
GetConsoleHandle
- HANDLE Return
ChangeState
Sets the state of the bus. SPI - Controls the chip select pin I2C - Controls the start/restart/stop status
- BYTE State
SPI: 0=CSLow, 1=CSHigh I2C: 0=Stop, 1=Start, 2=Restart, 3=LastRx
SCADA Slave
InitialiseInjector
TxByte
- BYTE DataByte
RxByte
GetConsoleHandle
- HANDLE Return
ChangeState
- BYTE State
SCADA Slave
InitialiseInjector
TxByte
- BYTE DataByte
RxByte
GetConsoleHandle
- HANDLE Return
ChangeState
- BYTE State
SCADA Slave
