Component: API I2C Dummy (API Slave Devices)
| Version | 2.0 |
API I2C Dummy component
API I2C Dummy
Please click here to download the component source project: FC_Comp_Source_API_I2C_Dummy.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_API_I2C_Dummy.fcfx
| I2CInitialise | |
| Initialsie the I2C module ready for communications | |
| Channel | |
| Baud | |
| I2CRestart | |
| Put the I2C Module into Restart mode | |
| Channel | |
| I2CStart | |
| Put the I2C Module into Start mode | |
| Channel | |
| I2CReceive | |
| Receive a byte using the I2C bus | |
| Channel | |
| Last | |
| I2CStop | |
| Put the I2C Module into Stop mode | |
| Channel | |
| I2CSend | |
| Channel | |
| DataOut | |
| Properties |
| I2CInitialise | |
| Channel | |
| Baud | |
| I2CRestart | |
| Channel | |
| I2CStart | |
| Channel | |
| I2CReceive | |
| Channel | |
| Last | |
| I2CStop | |
| Channel | |
| I2CSend | |
| Channel | |
| DataOut | |
| Properties |
| I2CInitialise | |
| Channel | |
| Baud | |
| I2CRestart | |
| Channel | |
| I2CStart | |
| Channel | |
| I2CReceive | |
| Channel | |
| Last | |
| I2CStop | |
| Channel | |
| I2CSend | |
| Channel | |
| DataOut | |
| Properties |
| I2CInitialise | |
| Channel | |
| Baud | |
| I2CRestart | |
| Channel | |
| I2CStart | |
| Channel | |
| I2CReceive | |
| Channel | |
| Last | |
| I2CStop | |
| Channel | |
| I2CSend | |
| Channel | |
| DataOut | |
| Properties |
