Component: Digital Temperature (EBM004) (EBM Modules)
Revision as of 09:55, 27 January 2023 by Wiki bot (talk | contribs)
Version 2.0
Category EBM Modules
Digital Temperature component
A digital temperature sensor based around the LM75B chip.
Please click here to download the component source project: FC_Comp_Source_EBM004v1.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_EBM004v1.fcfx
This example simply reads the value from the digital temperature sensor and outputs the value to an LCD as a temperature in degrees C.
EBM004 Example
ReadInt
Read double byte data from register at address
- BYTE address
- INT Return
ReadFloat
Reads the temperature value as a float
- FLOAT Return
WriteByte
- BYTE address
- BYTE data
WriteInt
- BYTE address
- UINT data
ReadByte
Read a single byte at a specific address from the chip's internal memory.
- BYTE address
Uninit
Uninitialise and release resources
Initialise to default of 11 bit resolution
Channel selection
SDA
SCL
Baud Select
Baud rate to be used
Stop Delay
Simulation Comms
Simulation GUI
Min. Temp.
Minimum termperature that can be set or displayed on the thermometer slider.
Max. Temp.
Maximum termperature that can be set or displayed on the thermometer slider.
Scale divisions
Number of numbered divisions shown on the thermometer scale.
I2C Data
Set whether the I2C data is displayed as decimal or hexadecimal numbers.
ReadInt
- BYTE address
- INT Return
ReadFloat
- FLOAT Return
WriteByte
- BYTE address
- BYTE data
WriteInt
- BYTE address
- UINT data
ReadByte
- BYTE address
Uninit
Channel selection
SDA
SCL
Baud Select
Stop Delay
Simulation Comms
Simulation GUI
Min. Temp.
Max. Temp.
Scale divisions
I2C Data
ReadInt
- BYTE address
- INT Return
ReadFloat
- FLOAT Return
WriteByte
- BYTE address
- BYTE data
WriteInt
- BYTE address
- UINT data
ReadByte
- BYTE address
Uninit
Channel selection
SDA
SCL
Baud Select
Stop Delay
Simulation Comms
Simulation GUI
Min. Temp.
Max. Temp.
Scale divisions
I2C Data
ReadInt
- BYTE address
- INT Return
ReadFloat
- FLOAT Return
WriteByte
- BYTE address
- BYTE data
WriteInt
- BYTE address
- UINT data
ReadByte
- BYTE address
Uninit
Channel selection
SDA
SCL
Baud Select
Stop Delay
Simulation Comms
Simulation GUI
Min. Temp.
Max. Temp.
Scale divisions
I2C Data
