Component: Ultrasonic (EBM019) (EBM Modules)
Revision as of 09:56, 27 January 2023 by Wiki bot (talk | contribs)
Category EBM Modules
Ultrasonic component
This board has both an ultrasonic transmitter and receiver. The transmitter is driven by an on-board 40KHz oscillator which is enabled by the host microprocessor. The receiving sensor signal is amplified and provided as an analogue signal to be processed by a single channel ADC of the microprocessor. By measuring the time delay between enabling a transmit pulse and receiving an echo the distance of objects in a range of around 3cm to 3m can be determined.
Please click here to download the component source project: FC_Comp_Source_EBM019v1.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_EBM019v1.fcfx
Sample program using the EBM019 - Ultrasonic sensor.
Sends out a pulse and determines distance from time taken to receive reflection.
EBM019 Example
GetDistance
Sends a pulse and processes the echo. Returns a object distance in cm
SetDelayTime
Set the delay time before sampling for the echo, in microseconds
- UINT delay
delay time in microseconds
SetDetectionValue
Set the delta value for echo detection
- BYTE value
trigger point for echo detection
SetPulseWidth
Set the output pulse width, in microsecond (0-255uS)
- BYTE pulse
width of pulse in microseconds
Setup the device. This sets the control output to logic 0
Output Pulse Pin
Pin used for controlling the output pulse
Echo ADC channel
ADC channel used to monitor the echo
Pulse Width (uS)
Output ultrasonic pulse width in microseconds
Read Delay (uS)
Time delay in microseconds before sampling for echo
Pulse Detection Value
Detection ADC delta trigger value A lower value is more sensitive
GetDistance
SetDelayTime
- UINT delay
SetDetectionValue
- BYTE value
SetPulseWidth
- BYTE pulse
Output Pulse Pin
Echo ADC channel
Pulse Width (uS)
Read Delay (uS)
GetDistance
SetDelayTime
- UINT delay
SetDetectionValue
- BYTE value
SetPulseWidth
- BYTE pulse
Output Pulse Pin
Echo ADC channel
Pulse Width (uS)
Read Delay (uS)
GetDistance
SetDelayTime
- UINT delay
SetDetectionValue
- BYTE value
SetPulseWidth
- BYTE pulse
Output Pulse Pin
Echo ADC channel
Pulse Width (uS)
Read Delay (uS)
