Component: FLASH (CAL) (Misc)
| Category | Misc |
FLASH (CAL) component
CAL - Code Abstraction Layer A low level implementation giving direct access to Flash read and write routines.
Please click here to download the component source project: FC_Comp_Source_FLASH.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_FLASH.fcfx
| WriteInstructionRow | |
| Writes a complete row of instructions to the device memory. Takes the values from the data array. | |
| Address | |
| Data | |
| ErasePage | |
| Erase the minimum amount of flash (usually a page) at the selected address. | |
| Address | |
| Start address of page | |
| ReadInstruction | |
| Reads a single instruction from the device memory. Loads the result into the Data array. | |
| Address | |
| Data | |
| WriteInstruction | |
| Writes a the minimum number of instructions to the device memory. Takes the values from the data array. | |
| Address | |
| Data | |
| EraseAll | |
| Erase all flash memory locations on the device. | |
| Aux | |
| 0=Primary Flash, 1=Aux Flash if available | |
| Address | |
| Data | |
| ErasePage | |
| Address | |
| ReadInstruction | |
| Address | |
| Data | |
| Address | |
| Data | |
| EraseAll | |
| Aux | |
| Address | |
| Data | |
| ErasePage | |
| Address | |
| ReadInstruction | |
| Address | |
| Data | |
| Address | |
| Data | |
| EraseAll | |
| Aux | |
| Address | |
| Data | |
| ErasePage | |
| Address | |
| ReadInstruction | |
| Address | |
| Data | |
| Address | |
| Data | |
| EraseAll | |
| Aux | |
