Component: GPS (EB056, Generic NMEA) (Wireless)
Revision as of 09:57, 27 January 2023 by Wiki bot (talk | contribs)
Author Matrix Ltd.
Version 2.1
Category Wireless
GPS (EB056, Generic NMEA) component
Component designed to process incoming NMEA style GPS data and convert into meaningful values such as longitude, lattitude, ground speed, UTC date and time. Also available in the form of the EB056 GPS E-block.
Please click here to download the component source project: FC_Comp_Source_GPS.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_GPS.fcfx
GPS Example File GPS Example Example should show the Latitude generated by the GPS injector as well as the system time in simulation or UTC time on hardware.
Example data provided by the GPS NMEA injector component
GPS tracking application using an Arduino and an SD card reader. GPS Tracker
ReadGroundSpeed
Returns the current ground speed. Only returns correct data if Log Ground Speed property is set to yes.
- FLOAT Return
ReadNumberOfSatellites
Returns the current detected number of satellites. Only returns correct data if Log Satellite Count property is set to yes.
ReadDilutionOfPrecision
Returns the current dilution of precision. Only returns correct data if Log Dilution Of Precision property is set to yes.
- FLOAT Return
CheckBufferOverflow
Returns the state of the buffer - 0 = OK, 1 = BufferTooShort, 2 = ItemNotFound. Only returns correct data if Log Buffer Overflow Property is set to Yes.
ReadLongitude
Returns the current longitude. Only returns correct data if Log Longitude property is set to yes.
- FLOAT Return
ReadUTCTime
Returns a segment of the current UTC Time. Only returns correct data if Log UTC Time property is set to yes.
- BYTE Unit
Specifies which segment to read - 'h', 'm', 's'
IsDataValid
Returns the state of the incoming data - 0 = NotValid, 1 = Valid 255 = No GPS Data Received.
ReadHorizontalDilutionOfPrecision
Returns the current horizontal dilution of precision. Only returns correct data if Log HDOP property is set to yes.
- FLOAT Return
ReadAltitude
Returns the current altitude. Only returns correct data if Log Altitude property is set to yes.
- FLOAT Return
ReadCourseOverGround
Returns the current course over ground. Only returns correct data if Log Course Over Ground property is set to yes.
- FLOAT Return
ReadUTCDate
Returns a segment of the current UTC Date. Only returns correct data if Log UTC Date property is set to yes.
- BYTE Unit
Specifies which segment to read - 'd', 'm', 'y'
ReadVerticalDilutionOfPrecision
Returns the current vertical dilution of precision. Only returns correct data if Log VDOP property is set to yes.
- FLOAT Return
ReadLatitude
Returns the current latitude. Only returns correct data if Log Latitude property is set to yes.
- FLOAT Return
Initialises the UART used to communicate with the GPS module.
Buffer Size
The maximum number of bytes of a NMEA message we can store before processing the message.
Log Altitude
Adds a variable to store the incoming altitude value Referenced by macro: ReadAltitude
Log Buffer Overflow
Adds a variable to store if the incoming message buffer overflows Referenced by macro: CheckBufferOverflow
Adds a variable to store the incoming course over ground value Referenced by macro: ReadCourseOverGround
Adds a variable to store the incoming DOP value Referenced by macro: ReadDilutionOfPrecision
Log Ground Speed
Adds a variable to store the incoming ground speed value Referenced by macro: ReadGroundSpeed
Log Horizontal DOP
Adds a variable to store the incoming HDOP value Referenced by macro: ReadHorizontalDilutionOfPrecision
Log Latitude
Adds a variable to store the incoming latitude value Referenced by macro: ReadLatitude
Log Longitude
Adds a variable to store the incoming longitude value Referenced by macro: Read Longitude
Log Satellite Count
Adds a variable to store the number of satellites in range Referenced by macro: ReadNumberOfSatellites
Log UTC Time
Adds a variable to store the incoming UTC Time value Referenced by macro: ReadUTCTime
Log UTC Date
Adds a variable to store the incoming UTC Date value Referenced by macro: ReadUTCDate
Log Verticle DOP
Adds a variable to store the incoming VDOP value Referenced by macro: ReadVerticalDilutionOfPrecision
RX
Baud Options
Show Globe
Allows a graphical globe to be shown on the panel along with a coordinate marker.
Console Columns
Data Source
ReadGroundSpeed
- FLOAT Return
- FLOAT Return
CheckBufferOverflow
ReadLongitude
- FLOAT Return
ReadUTCTime
- BYTE Unit
IsDataValid
- FLOAT Return
ReadAltitude
- FLOAT Return
- FLOAT Return
ReadUTCDate
- BYTE Unit
- FLOAT Return
ReadLatitude
- FLOAT Return
Buffer Size
Log Altitude
Log Buffer Overflow
Log Ground Speed
Log Horizontal DOP
Log Latitude
Log Longitude
Log Satellite Count
Log UTC Time
Log UTC Date
Log Verticle DOP
RX
Baud Options
Show Globe
Console Columns
Data Source
ReadGroundSpeed
- FLOAT Return
- FLOAT Return
CheckBufferOverflow
ReadLongitude
- FLOAT Return
ReadUTCTime
- BYTE Unit
IsDataValid
- FLOAT Return
ReadAltitude
- FLOAT Return
- FLOAT Return
ReadUTCDate
- BYTE Unit
- FLOAT Return
ReadLatitude
- FLOAT Return
Buffer Size
Log Altitude
Log Buffer Overflow
Log Ground Speed
Log Horizontal DOP
Log Latitude
Log Longitude
Log Satellite Count
Log UTC Time
Log UTC Date
Log Verticle DOP
RX
Baud Options
Show Globe
Console Columns
Data Source
ReadGroundSpeed
- FLOAT Return
- FLOAT Return
CheckBufferOverflow
ReadLongitude
- FLOAT Return
ReadUTCTime
- BYTE Unit
IsDataValid
- FLOAT Return
ReadAltitude
- FLOAT Return
- FLOAT Return
ReadUTCDate
- BYTE Unit
- FLOAT Return
ReadLatitude
- FLOAT Return
Buffer Size
Log Altitude
Log Buffer Overflow
Log Ground Speed
Log Horizontal DOP
Log Latitude
Log Longitude
Log Satellite Count
Log UTC Time
Log UTC Date
Log Verticle DOP
RX
Baud Options
Show Globe
Console Columns
Data Source
