| Author
Matrix Ltd
| Version
1.1
| Category
Misc
Motion Helper component
Helper for building components which require simulation of constant motion. Linked objects can be issued speed and acceleration parameters, and will then be animated automatically until another command is issued. The helper can control motion for up to four objects simultaneously, all with their own discrete motion settings.
Please click here to download the component source project: FC_Comp_Source_Motion_Helper.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_Motion_Helper.fcfx
Example showing how to use the motion helper component to easily assign motion to items on the panel.
Motion
RegisterTarget
| Add a new object to the list of objects which the motion helper is animating. Up to four objects can be animated by each Motion Helper.
- HANDLE
Target
| Handle of the target to link to.
- HANDLE
AxisObject
| Axis object for this definition
- BYTE
Axis
| Axis to move along/around (0=X, 1=Y, 2=Z)
- BYTE
Type
| Motion type (0=Rotary, 1=Linear)
SetAcceleration
| Sets the acceleration for the target object. This sets how quickly the object reaches its new speed following a call to SetSpeed. NB) The object must be one of those registered using RegisterTarget.
- HANDLE
Target
| Handle of the object to set the acceleration for.
- FLOAT
Acceleration
| Time in milliseconds to reach a new speed.
SetSpeed
| Set a new target speed for this object. Will use the acceleration parameter to set how long it will take to reach the new speed. NB) The object must be one of those previously declared using RegisterTarget
- HANDLE
Target
| Target object to set the speed for.
- FLOAT
Speed
| Target speed. World units per second or degrees per second.
UnregisterTarget
| Remove a target from the list of links.
- HANDLE
Target
| Handle of the object to remove
UnregisterAll
| Totally clear the list of registered objects
Frame Interval
| Time interval between animation frames. Does not affect the speed of motion, only the rate of screen updates.
On Stop
| Decide what action to take when simulation stops. No Action - Animation is paused, continues from this position when simulation restarts Return to start - all object returned to their start positions, current speed resumes on simulation start. Clear speeds - objects retain their position, but speed is set to zero. Return and clear - objects return to start position and have theri speed set to zero.
RegisterTarget
- HANDLE
Target
- HANDLE
AxisObject
- BYTE
Axis
- BYTE
Type
SetAcceleration
- HANDLE
Target
- FLOAT
Acceleration
SetSpeed
- HANDLE
Target
- FLOAT
Speed
UnregisterTarget
- HANDLE
Target
UnregisterAll
Frame Interval
On Stop
RegisterTarget
- HANDLE
Target
- HANDLE
AxisObject
- BYTE
Axis
- BYTE
Type
SetAcceleration
- HANDLE
Target
- FLOAT
Acceleration
SetSpeed
- HANDLE
Target
- FLOAT
Speed
UnregisterTarget
- HANDLE
Target
UnregisterAll
Frame Interval
On Stop
RegisterTarget
- HANDLE
Target
- HANDLE
AxisObject
- BYTE
Axis
- BYTE
Type
SetAcceleration
- HANDLE
Target
- FLOAT
Acceleration
SetSpeed
- HANDLE
Target
- FLOAT
Speed
UnregisterTarget
- HANDLE
Target
UnregisterAll
Frame Interval
On Stop
