Component: Joystick (Sparkfun Quiic) 2D (Analog Input)
Revision as of 09:59, 27 January 2023 by Wiki bot (talk | contribs)
Category Analog Input
Joystick (Sparkfun Quiic) 2D component
An XY sprung joystick with click switch allowing for easy user input control. Connected using I2C bus.
Please click here to download the component source project: FC_Comp_Source_Sparkfun_Quiic_Joystick_2dgi.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_Sparkfun_Quiic_Joystick_2dgi.fcfx
ChangeI2CAddress
Allows the I2C Device address to be changed which in turn allows more then one RFID reader to sit on the same physical I2C bus. Returns 1 if succesful.
- BYTE NewAddress
Range: 8 to 119 or 0x08 - 0x77
- BOOL Return
CheckButton
Checks to see if the button has been pressed since the last read of CheckButton or ReadButton.
- BOOL Return
ReadAxis
Reads a single axis of the joystick and returns as a signed integer value.
- BYTE Axis
Range 0-1 Where 0=X, 1=Y
- BOOL Type
0 = Signed (-512 to 511), 1 = Unsigned (0 to 1023)
- INT Return
SimMoveThumbStick
- FLOAT X
- FLOAT Y
- HANDLE Component
ReadButton
Checks to see if the button is currently pressed
- BOOL Return
Initialises the I2C bus ready for communications with the module.
Return To Center
Decides if the joystick automatically returns to the center position when released. Yes: The joystick will return to the center when released. No: The joystick will remain in the current position when released.
Limits
X Min
X Max
Device Address
Theme
Box Colour
Shaft Colour
Knob Colour
Style
Style
Outline line style
Channel selection
Baud Select
SDA
SDA Remap Pin
SCL
SCL Remap Pin
Stop Delay
Simulate Comms
API
Specifies the API component on the panel to interact with to provide comms simulation.
ChangeI2CAddress
- BYTE NewAddress
- BOOL Return
CheckButton
- BOOL Return
ReadAxis
- BYTE Axis
- BOOL Type
- INT Return
SimMoveThumbStick
- FLOAT X
- FLOAT Y
- HANDLE Component
ReadButton
- BOOL Return
Return To Center
Limits
X Min
X Max
Device Address
Theme
Box Colour
Shaft Colour
Knob Colour
Style
Style
Outline line style
Channel selection
Baud Select
SDA
SDA Remap Pin
SCL
SCL Remap Pin
Stop Delay
Simulate Comms
API
ChangeI2CAddress
- BYTE NewAddress
- BOOL Return
CheckButton
- BOOL Return
ReadAxis
- BYTE Axis
- BOOL Type
- INT Return
SimMoveThumbStick
- FLOAT X
- FLOAT Y
- HANDLE Component
ReadButton
- BOOL Return
Return To Center
Limits
X Min
X Max
Device Address
Theme
Box Colour
Shaft Colour
Knob Colour
Style
Style
Outline line style
Channel selection
Baud Select
SDA
SDA Remap Pin
SCL
SCL Remap Pin
Stop Delay
Simulate Comms
API
ChangeI2CAddress
- BYTE NewAddress
- BOOL Return
CheckButton
- BOOL Return
ReadAxis
- BYTE Axis
- BOOL Type
- INT Return
SimMoveThumbStick
- FLOAT X
- FLOAT Y
- HANDLE Component
ReadButton
- BOOL Return
Return To Center
Limits
X Min
X Max
Device Address
Theme
Box Colour
Shaft Colour
Knob Colour
Style
Style
Outline line style
Channel selection
Baud Select
SDA
SDA Remap Pin
SCL
SCL Remap Pin
Stop Delay
Simulate Comms
API
