Component: Digital Potentiometer (X9Cx0x) (Analog Output)
| Category | Analog Output |
Digital Potentiometer (X9Cx0x) component
The X9Cx0x device range supports a digital potentiometers outputs. 100 possible wiper tap points available. Supported devices include X9C102, X9C103, X9C104, X9C503.
Please click here to download the component source project: FC_Comp_Source_X9C_Digital_Pot.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_X9C_Digital_Pot.fcfx
| IncrementWiper | |
| Increments a single volatile wiper value | |
| DecrementWiper | |
| Decrements a single volatile wiper value | |
| DecrementXTimes | |
| Decrements the wiper value the specified number of times | |
| Count | |
| Range: 1-99 | |
| IncrementXTimes | |
| Increments the wiper value the specified number of times | |
| Count | |
| Range: 1-99 | |
| Properties | |
| Device Connections | |
| CS Pin | |
| Chip Select Pin, Active Low | |
| Increment Pin | |
| Increment Pin, Active Low | |
| Up/Down Pin | |
| Up Down Pin, Low = Down, High = Up | |
| IncrementWiper | |
| DecrementWiper | |
| DecrementXTimes | |
| Count | |
| Range: 1-99 | |
| IncrementXTimes | |
| Count | |
| Range: 1-99 | |
| Properties | |
| CS Pin | |
| Increment Pin | |
| Up/Down Pin | |
| IncrementWiper | |
| DecrementWiper | |
| DecrementXTimes | |
| Count | |
| Range: 1-99 | |
| IncrementXTimes | |
| Count | |
| Range: 1-99 | |
| Properties | |
| CS Pin | |
| Increment Pin | |
| Up/Down Pin | |
| IncrementWiper | |
| DecrementWiper | |
| DecrementXTimes | |
| Count | |
| Range: 1-99 | |
| IncrementXTimes | |
| Count | |
| Range: 1-99 | |
| Properties | |
| CS Pin | |
| Increment Pin | |
| Up/Down Pin | |
