Component: API (Arduino Mega) (API Slave Devices)
Revision as of 09:54, 27 January 2023 by Wiki bot (talk | contribs)
Version 2.0
Category API Slave Devices
API (Arduino Mega) component
Connects to an Arduino Mega running the API Firmware allowing the board to become a slave to the Flowcode Embedded simulation or Flowcode App Developer. Supports: Digital IO / ADC / I2C / SPI / UART / PWM See Flowcode Help Wiki for firmware.
Please click here to download the component source project: FC_Comp_Source_Arduino_Mega_API_Comp.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_Arduino_Mega_API_Comp.fcfx
I2CInitialise
- BYTE Channel
- BYTE Baud
0=100KHz, 1=400KHz, 2=1MHz
ADCSampleArray8
Reads the voltage present on an Analog pin as an 8-bit value range 0-255 Performs the selected number of samples with the selected time in microseconds in between samples and returns each sample in a single packet
- BYTE ADCChannel
Range: 0-5
- BYTE SampleCount
Range: 1- 32
- UINT SampleDelay
- BYTE Samples
8-bit samples returned from the function
SPITransferTrans
- BYTE Channel
- UINT Count
- BYTE DataOut
Outgoing data
- BYTE DataIn
Incoming data
IOGetInputPin
- BYTE Pin
Range: 0-53
- BOOL Return
UARTBaud
- BYTE Channel
- BYTE Rate
ADCSample8
- BYTE ADCChannel
Range: 0-15
I2CTransReceive
- BYTE Channel
- BYTE Data
Data variable to receive into
- UINT Count
Number of bytes to receive
UARTCheckRX
- BYTE Channel
UARTInitialise
- BYTE Channel
RegisterWrite
Writes to one of the registers on-board the device
- UINT RegisterAddress
The address of the register
- BYTE Data
The data value to assign to the register
ADCSetPrechargeTime
Specifies the precharge time for the ADC input readings in microseconds. The longer the time the more immune to noise the reading will be.
- BYTE ChargeTime
Default 10
RegisterRead
Read one of the registers on-board the device
I2CRestart
- BYTE Channel
PWMDisable
Disable a PWM output
- BYTE Channel
Range: 0-15
I2CStart
- BYTE Channel
SPITransfer
- BYTE Channel
- BYTE DataOut
I2CReceive
- BYTE Channel
- BOOL Last
I2CStop
- BYTE Channel
ADCSetReferenceVoltage
Specified the reference setting for ADC reads.
- BYTE RefType
0=AREF, 1=VCC, 3=Internal 1.1V
SPIPrescaler
- BYTE Channel
- BYTE Prescaler
Range: 0-2
PWMSetDuty
- BYTE Channel
Range: 0-15
- BYTE Duty
ADCSample10
Reads the voltage present on an Analog pin as an 10-bit value range 0-1023
- BYTE ADCChannel
Range: 0-15
I2CTransSend
- BYTE Channel
- BYTE Data
Data to send
- UINT Count
IOSetOutputPin
- BYTE Pin
Range: 0-53
- BOOL State
Range: 0-1
UARTReceive
- BYTE Channel
ADCSampleAverage10
- BYTE ADCChannel
Range: 0-5
- BYTE SampleCount
Range: 1- 100
- BYTE SampleDelay
I2CTransInit
- BYTE Channel
- BYTE DeviceAddress
7-bit Device Address
- BYTE Baud
SPIInitialise
- BYTE Channel
I2CSend
- BYTE Channel
- BYTE DataOut
- BOOL Return
UARTSend
- BYTE Channel
- BYTE Data
PWMSetPrescaler
- BYTE Channel
Range: 0-15
- BYTE Prescaler
- BYTE Period
Default 255
PWMEnable
Enable a PWM output
- BYTE Channel
Range: 0-15
ADCSampleArray10
- BYTE ADCChannel
Range: 0-5
- BYTE SampleCount
Range: 1- 32
- UINT SampleDelay
- UINT Samples
ADCSampleAverage8
- BYTE ADCChannel
Range: 0-5
- BYTE SampleCount
Range: 1- 100
- BYTE SampleDelay
Connection
COM Port
Lists all the current available COM port hardware on your PC.
Refresh Ports
API Peripherals
Digital IO
Analog Input
Analog Output
PWM Output
I2C Bus
SPI Bus
UART
Servo
Console
Console Log
Create an automatic console log of the commands sent to the Arduino
Log Mode
Controls how the console data is formatted. Fixed statistics gives an easy to read overview of the IO, Analog and PWM functionality Command Log gives a more in depth analysis of the outgoing commands and incoming returns
I2CInitialise
- BYTE Channel
- BYTE Baud
ADCSampleArray8
- BYTE ADCChannel
Range: 0-5
- BYTE SampleCount
Range: 1- 32
- UINT SampleDelay
- BYTE Samples
SPITransferTrans
- BYTE Channel
- UINT Count
- BYTE DataOut
Outgoing data
- BYTE DataIn
Incoming data
IOGetInputPin
- BYTE Pin
Range: 0-53
- BOOL Return
UARTBaud
- BYTE Channel
- BYTE Rate
ADCSample8
- BYTE ADCChannel
Range: 0-15
I2CTransReceive
- BYTE Channel
- BYTE Data
- UINT Count
UARTCheckRX
- BYTE Channel
UARTInitialise
- BYTE Channel
RegisterWrite
- BYTE Data
ADCSetPrechargeTime
- BYTE ChargeTime
Default 10
RegisterRead
I2CRestart
- BYTE Channel
PWMDisable
- BYTE Channel
Range: 0-15
I2CStart
- BYTE Channel
SPITransfer
- BYTE Channel
- BYTE DataOut
I2CReceive
- BYTE Channel
- BOOL Last
I2CStop
- BYTE Channel
- BYTE RefType
SPIPrescaler
- BYTE Channel
- BYTE Prescaler
Range: 0-2
PWMSetDuty
- BYTE Channel
Range: 0-15
- BYTE Duty
ADCSample10
- BYTE ADCChannel
Range: 0-15
I2CTransSend
- BYTE Channel
- BYTE Data
Data to send
- UINT Count
IOSetOutputPin
- BYTE Pin
Range: 0-53
- BOOL State
Range: 0-1
UARTReceive
- BYTE Channel
ADCSampleAverage10
- BYTE ADCChannel
Range: 0-5
- BYTE SampleCount
Range: 1- 100
- BYTE SampleDelay
I2CTransInit
- BYTE Channel
- BYTE Baud
SPIInitialise
- BYTE Channel
I2CSend
- BYTE Channel
- BYTE DataOut
- BOOL Return
UARTSend
- BYTE Channel
- BYTE Data
PWMSetPrescaler
- BYTE Channel
Range: 0-15
- BYTE Prescaler
- BYTE Period
Default 255
PWMEnable
Enable a PWM output
- BYTE Channel
Range: 0-15
ADCSampleArray10
- BYTE ADCChannel
Range: 0-5
- BYTE SampleCount
Range: 1- 32
- UINT SampleDelay
- UINT Samples
ADCSampleAverage8
- BYTE ADCChannel
Range: 0-5
- BYTE SampleCount
Range: 1- 100
- BYTE SampleDelay
Connection
COM Port
Refresh Ports
API Peripherals
Digital IO
Analog Input
Analog Output
PWM Output
I2C Bus
SPI Bus
UART
Servo
Console
Console Log
Log Mode
I2CInitialise
- BYTE Channel
- BYTE Baud
ADCSampleArray8
- BYTE ADCChannel
Range: 0-5
- BYTE SampleCount
Range: 1- 32
- UINT SampleDelay
- BYTE Samples
SPITransferTrans
- BYTE Channel
- UINT Count
- BYTE DataOut
Outgoing data
- BYTE DataIn
Incoming data
IOGetInputPin
- BYTE Pin
Range: 0-53
- BOOL Return
UARTBaud
- BYTE Channel
- BYTE Rate
ADCSample8
- BYTE ADCChannel
Range: 0-15
I2CTransReceive
- BYTE Channel
- BYTE Data
- UINT Count
UARTCheckRX
- BYTE Channel
UARTInitialise
- BYTE Channel
RegisterWrite
- BYTE Data
ADCSetPrechargeTime
- BYTE ChargeTime
Default 10
RegisterRead
I2CRestart
- BYTE Channel
PWMDisable
- BYTE Channel
Range: 0-15
I2CStart
- BYTE Channel
SPITransfer
- BYTE Channel
- BYTE DataOut
I2CReceive
- BYTE Channel
- BOOL Last
I2CStop
- BYTE Channel
- BYTE RefType
SPIPrescaler
- BYTE Channel
- BYTE Prescaler
Range: 0-2
PWMSetDuty
- BYTE Channel
Range: 0-15
- BYTE Duty
ADCSample10
- BYTE ADCChannel
Range: 0-15
I2CTransSend
- BYTE Channel
- BYTE Data
Data to send
- UINT Count
IOSetOutputPin
- BYTE Pin
Range: 0-53
- BOOL State
Range: 0-1
UARTReceive
- BYTE Channel
ADCSampleAverage10
- BYTE ADCChannel
Range: 0-5
- BYTE SampleCount
Range: 1- 100
- BYTE SampleDelay
I2CTransInit
- BYTE Channel
- BYTE Baud
SPIInitialise
- BYTE Channel
I2CSend
- BYTE Channel
- BYTE DataOut
- BOOL Return
UARTSend
- BYTE Channel
- BYTE Data
PWMSetPrescaler
- BYTE Channel
Range: 0-15
- BYTE Prescaler
- BYTE Period
Default 255
PWMEnable
Enable a PWM output
- BYTE Channel
Range: 0-15
ADCSampleArray10
- BYTE ADCChannel
Range: 0-5
- BYTE SampleCount
Range: 1- 32
- UINT SampleDelay
- UINT Samples
ADCSampleAverage8
- BYTE ADCChannel
Range: 0-5
- BYTE SampleCount
Range: 1- 100
- BYTE SampleDelay
Connection
COM Port
Refresh Ports
API Peripherals
Digital IO
Analog Input
Analog Output
PWM Output
I2C Bus
SPI Bus
UART
Servo
Console
Console Log
Log Mode
I2CInitialise
- BYTE Channel
- BYTE Baud
ADCSampleArray8
- BYTE ADCChannel
Range: 0-5
- BYTE SampleCount
Range: 1- 32
- UINT SampleDelay
- BYTE Samples
SPITransferTrans
- BYTE Channel
- UINT Count
- BYTE DataOut
Outgoing data
- BYTE DataIn
Incoming data
IOGetInputPin
- BYTE Pin
Range: 0-53
- BOOL Return
UARTBaud
- BYTE Channel
- BYTE Rate
ADCSample8
- BYTE ADCChannel
Range: 0-15
I2CTransReceive
- BYTE Channel
- BYTE Data
- UINT Count
UARTCheckRX
- BYTE Channel
UARTInitialise
- BYTE Channel
RegisterWrite
- BYTE Data
ADCSetPrechargeTime
- BYTE ChargeTime
Default 10
RegisterRead
I2CRestart
- BYTE Channel
PWMDisable
- BYTE Channel
Range: 0-15
I2CStart
- BYTE Channel
SPITransfer
- BYTE Channel
- BYTE DataOut
I2CReceive
- BYTE Channel
- BOOL Last
I2CStop
- BYTE Channel
- BYTE RefType
SPIPrescaler
- BYTE Channel
- BYTE Prescaler
Range: 0-2
PWMSetDuty
- BYTE Channel
Range: 0-15
- BYTE Duty
ADCSample10
- BYTE ADCChannel
Range: 0-15
I2CTransSend
- BYTE Channel
- BYTE Data
Data to send
- UINT Count
IOSetOutputPin
- BYTE Pin
Range: 0-53
- BOOL State
Range: 0-1
UARTReceive
- BYTE Channel
ADCSampleAverage10
- BYTE ADCChannel
Range: 0-5
- BYTE SampleCount
Range: 1- 100
- BYTE SampleDelay
I2CTransInit
- BYTE Channel
- BYTE Baud
SPIInitialise
- BYTE Channel
I2CSend
- BYTE Channel
- BYTE DataOut
- BOOL Return
UARTSend
- BYTE Channel
- BYTE Data
PWMSetPrescaler
- BYTE Channel
Range: 0-15
- BYTE Prescaler
- BYTE Period
Default 255
PWMEnable
Enable a PWM output
- BYTE Channel
Range: 0-15
ADCSampleArray10
- BYTE ADCChannel
Range: 0-5
- BYTE SampleCount
Range: 1- 32
- UINT SampleDelay
- UINT Samples
ADCSampleAverage8
- BYTE ADCChannel
Range: 0-5
- BYTE SampleCount
Range: 1- 100
- BYTE SampleDelay
Connection
COM Port
Refresh Ports
API Peripherals
Digital IO
Analog Input
Analog Output
PWM Output
I2C Bus
SPI Bus
UART
Servo
Console
Console Log
Log Mode
I2CInitialise
- BYTE Channel
- BYTE Baud
ADCSampleArray8
- BYTE ADCChannel
Range: 0-5
- BYTE SampleCount
Range: 1- 32
- UINT SampleDelay
- BYTE Samples
SPITransferTrans
- BYTE Channel
- UINT Count
- BYTE DataOut
Outgoing data
- BYTE DataIn
Incoming data
IOGetInputPin
- BYTE Pin
Range: 0-53
- BOOL Return
UARTBaud
- BYTE Channel
- BYTE Rate
ADCSample8
- BYTE ADCChannel
Range: 0-15
I2CTransReceive
- BYTE Channel
- BYTE Data
- UINT Count
UARTCheckRX
- BYTE Channel
UARTInitialise
- BYTE Channel
RegisterWrite
- BYTE Data
ADCSetPrechargeTime
- BYTE ChargeTime
Default 10
RegisterRead
I2CRestart
- BYTE Channel
PWMDisable
- BYTE Channel
Range: 0-15
I2CStart
- BYTE Channel
SPITransfer
- BYTE Channel
- BYTE DataOut
I2CReceive
- BYTE Channel
- BOOL Last
I2CStop
- BYTE Channel
- BYTE RefType
SPIPrescaler
- BYTE Channel
- BYTE Prescaler
Range: 0-2
PWMSetDuty
- BYTE Channel
Range: 0-15
- BYTE Duty
ADCSample10
- BYTE ADCChannel
Range: 0-15
I2CTransSend
- BYTE Channel
- BYTE Data
Data to send
- UINT Count
IOSetOutputPin
- BYTE Pin
Range: 0-53
- BOOL State
Range: 0-1
UARTReceive
- BYTE Channel
ADCSampleAverage10
- BYTE ADCChannel
Range: 0-5
- BYTE SampleCount
Range: 1- 100
- BYTE SampleDelay
I2CTransInit
- BYTE Channel
- BYTE Baud
SPIInitialise
- BYTE Channel
I2CSend
- BYTE Channel
- BYTE DataOut
- BOOL Return
UARTSend
- BYTE Channel
- BYTE Data
PWMSetPrescaler
- BYTE Channel
Range: 0-15
- BYTE Prescaler
- BYTE Period
Default 255
PWMEnable
Enable a PWM output
- BYTE Channel
Range: 0-15
ADCSampleArray10
- BYTE ADCChannel
Range: 0-5
- BYTE SampleCount
Range: 1- 32
- UINT SampleDelay
- UINT Samples
ADCSampleAverage8
- BYTE ADCChannel
Range: 0-5
- BYTE SampleCount
Range: 1- 100
- BYTE SampleDelay
Connection
COM Port
Refresh Ports
API Peripherals
Digital IO
Analog Input
Analog Output
PWM Output
I2C Bus
SPI Bus
UART
Servo
Console
Console Log
Log Mode
