Component: Infrared Reflective Sensor (Grove 101020174) (Light)
Revision as of 16:48, 30 January 2023 by Wiki bot (talk | contribs)
Category Light
Infrared Reflective Sensor (Grove 101020174) component
Uses InfraRed light to detect if an external object is near to the sensor. Returns a digital signal which can represent detected or not detected states.
Please click here to download the component source project: FC_Comp_Source_Infrared_Reflective_Sensor.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_Infrared_Reflective_Sensor.fcfx
SampleSensor
Returns the state of the sensor pin.
Configures the I/O ready for the sensor to be sampled.
SIG Pin
Pin connected to the sensor element of the photo transistor
Sensitivity
Simulation range used to determine if the sense pin is active or not.
