Component: Combo (BL0114) (E-blocks 2)
| Category | E-blocks 2 |
- 1 Combo component
- 2 Component Source Code
- 3 Detailed description
- 4 Examples
- 5 Macro reference
- 5.1 Seg_ShowDigit
- 5.2 LCD_PrintFormattedNumber
- 5.3 LCD_RemapCharacter
- 5.4 LCD_ScrollDisplay
- 5.5 IO_SetPort
- 5.6 IO_SetLEDState
- 5.7 LCD_PrintFloat
- 5.8 IO_GetPort
- 5.9 LCD_Cursor
- 5.10 Seg_ShowSegments
- 5.11 LCD_Start
- 5.12 LCD_Command
- 5.13 LCD_RAMWrite
- 5.14 IO_ReadAnalogAsInt
- 5.15 LCD_PrintString
- 5.16 LCD_ClearLine
- 5.17 IO_GetSwitchState
- 5.18 IO_ReadAnalogAsByte
- 5.19 LCD_PrintAscii
- 5.20 LCD_PrintNumber
- 5.21 LCD_RawSend
- 5.22 LCD_Clear
- 6 Property reference
Combo component
A component to drive the BL0114 Combo board including LEDs, Switches, LCD, 7-Segs and analogue inputs.
Please click here to download the component source project: FC_Comp_Source_EBlocks2_COMBO_BL0114.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_EBlocks2_COMBO_BL0114.fcfx
Seg_ShowDigit
LCD_RemapCharacter
LCD_ScrollDisplay
IO_SetPort
|   | IO_SetPort |
| Sets the state of a single port | |
|  - BYTE | Bank |
| 0 = Top Bank of LEDs, 1 = Bottom Bank of LEDs | |
|  - BYTE | Value |
|  - VOID | Return |
IO_SetLEDState
|   | IO_SetLEDState |
| Sets the state of a single LED | |
|  - BYTE | Bank |
|  - BYTE | LED |
| 0 = LED0, 7 = LED7 | |
|  - BYTE | State |
| 0 = Off, 1 = On | |
|  - VOID | Return |
LCD_PrintFloat
IO_GetPort
|   | IO_GetPort |
| Reads the state of a single port | |
|  - BYTE | Bank |
| 0 = Top Bank of Switches, 1 = Bottom Bank of Switches | |
|  - BYTE | Return |
LCD_Cursor
Seg_ShowSegments
LCD_Start
|   | LCD_Start |
| Startup routine required by the hardware device. Automatically clears the display after initialising. | |
|  - VOID | Return |
LCD_Command
LCD_RAMWrite
IO_ReadAnalogAsInt
|   | IO_ReadAnalogAsInt |
| Reads one of the analogue components as an Integer value | |
|  - BYTE | Channel |
| 0 = Light Sensor, 1 = Potentiometer | |
|  - INT | Return |
LCD_PrintString
|   | LCD_PrintString |
| Breaks down a string of text and sends it to the LCD via the private RawSend(byte, mask) macro | |
|  - STRING | Text |
| Enter the text or variable to print to the LCD | |
|  - VOID | Return |
LCD_ClearLine
IO_GetSwitchState
IO_ReadAnalogAsByte
|   | IO_ReadAnalogAsByte |
| Reads one of the analogue components as an byte value | |
|  - BYTE | Channel |
|  - BYTE | Return |
LCD_PrintAscii
|   | LCD_PrintAscii |
| Takes the ascii value for a character and prints the character | |
|  - BYTE | character |
| Holds an ascii value. | |
|  - VOID | Return |
LCD_PrintNumber
|   | LCD_PrintNumber |
| Based on v5 macro, will allow you to print a number. This is limited to a signed-INT, -32768 to 32767 | |
|  - INT | Number |
| Enter the number or variable to print to the LCD | |
|  - VOID | Return |
LCD_RawSend
|   | LCD_RawSend |
| Sends data to the LCD display | |
|  - BYTE | data |
| The data byte to send to the LCD | |
|  - BOOL | type |
| A boolean to indicate command type: true to write data, false to write a command | |
|  - VOID | Return |
LCD_Clear
|   | LCD_Clear |
| Clears the entire contents of the display. | |
|  - VOID | Return |
