| Author
Matrix Ltd
| Version
2.0
| Category
E-blocks 1
GLCD (EB075) component
Graphical display component designed to work with the Goldelox range of displays from 4D Systems. Also available in the form of the EB075 GLCD E-block.
Please click here to download the component source project: FC_Comp_Source_GLCD_4D_EB075.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_GLCD_4D_EB075.fcfx
EB075 gLCD Example File
EB075 Example
G4D_InitialiseCard
G4D_InitialiseCard
| Initialises the micro SD card inserted into the module is available. Returns 0 for succesful initialisation or 255 for a detected failure. Does not currently simulate.
- BYTE
- INT
Number
- UINT
X
- UINT
Y
- BYTE
Font
| Size of the font - 0 = Normal, 1 = Double Width, 2 = Double Width and Height, 3 = Double Height
- BYTE
Transparent
DrawLine
DrawLine
- UINT
X1
- UINT
Y1
- UINT
X2
- UINT
Y2
DrawEllipse
DrawEllipse
- UINT
X
- UINT
Y
- UINT
XRadius
- UINT
YRadius
- BYTE
Transparent
- BYTE
Solid
Plot
Plot
- UINT
X1
- UINT
Y1
FastPlot
FastPlot
| Sets a pixel with the current foreground colour at current pixel location. Not compatible with orientations other than 0.
G4D_DisplayVideoFromCard
| Attempts to display a sequence of images from the micro SD card at the specified address location on the card. The images are printed at location starting from X, Y and ranging to Width, Height.
- UINT
X
- UINT
Y
- UINT
AddH
- UINT
AddL
- BYTE
BPlot
BPlot
- UINT
X1
- UINT
Y1
Window
Window
- UINT
X1
- UINT
Y1
- UINT
X2
- UINT
Y2
G4D_ReadJoystickGoldelox
| Reads the value of the joystick input. 0 = No press detected / 1 = Up Pressed / 2 = Left Pressed / 3 = Down Pressed / 4 = Right Pressed / 5 = Fire Pressed
- BYTE
Print
Print
- STRING
Str
- UINT
X1
- UINT
Y1
- BYTE
Font
- BYTE
Transparent
ClearDisplay
ClearDisplay
SetBackgroundColour
SetBackgroundColour
- BYTE
Red
| 0 - 255 where 0 = no red and 255 = maximum red
- BYTE
Green
| 0 - 255 where 0 = no green and 255 = maximum green
- BYTE
Blue
| 0 - 255 where 0 = no blue and 255 = maximum blue
DrawCircle
DrawCircle
- UINT
X
- UINT
Y
- UINT
Radius
- BYTE
Transparent
- BYTE
Solid
G4D_DisplayImageFromCard
| Attempts to print an image from the micro SD card at the specified address location on the card. The image is printed at location starting from X, Y and ranging to Width, Height.
- UINT
X
- UINT
Y
- UINT
AddH
| Byte Address High Word
- UINT
AddL
| Byte Address Low Word
- BYTE
SetForegroundColour
SetForegroundColour
- BYTE
Red
- BYTE
Green
- BYTE
Blue
DrawRectangle
DrawRectangle
- UINT
X1
- UINT
Y1
- UINT
X2
- UINT
Y2
- BYTE
Transparent
- BYTE
Solid
Dimensions
Pixel Height
Pixel Width
Colour
Monochrome
Foreground Color
Background Color
Bit Depth
Color Bit Depth
Red Bit Depth
Green Bit Depth
Blue Bit Depth
| UART Channel selector Software channels are bit banged using generic I/O pins but are not as reliable as hardware channels. Hardware channels use the selected peripheral on-board the target microcontroller.
TX
| Pin to be used for Transmit data
RX
| Pin to be used for Receive data
Reset Pin
| Reset pin connection
Baud Options
| Baud rate option selector
Component Label
Component Label Scale
Physical Orientation
| Selects if the scope traces are automatically added to the data recorder window or not. Simulation - draws an approximation of the UART data onto the scope trace. ICT - sets up the scope trace for incoming data and adds UART packet decoding at the correct BAUD.
Console Columns
| Number of characters that can be displayed on a single line of the console.
Data Source
| Simulation data source used to allow the component to connect to various remote devices Nothing - Simulation data is ignored COM port - Routes the communication data to and from a physical or virtual COM port Injector - Routes the communication data via a data injector component on the Panel.
