| Author
Matrix Ltd
| Version
2.5
| Category
Alphanumeric
LCD Base component
Generic configurable alphanumeric LCD display component based on the standard  Hitachi HD44780 controller IC wiith selectable 4/8 bit interface
Please click here to download the component source project: FC_Comp_Source_LCD_Base.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_LCD_Base.fcfx
For the LCDs to work with the Flowcode LCD component they need to be connected up in 4-bit data mode.
The 4 data signals actually go to the upper data nibble on the LCD as shown below.
Displaying a numeric value
The LCD will retain the contents of the display, for high speed data we only want to have to write to the portion of the display that can change.
LCD Demo
Clear
Clear
| Clears the entire contents of the display.
PrintString
PrintString
| Breaks down a string of text and sends it to the LCD via the private RawSend(byte, mask) macro
  - STRING
Text
| Enter the text or variable to print to the LCD
PrintAscii
PrintAscii
| Takes the ascii value for a character and prints the character
  - BYTE
character
| Holds an ascii value.
| Based on v5 macro, will allow you to print a number. This is limited to a signed-INT, -32768 to 32767
  - INT
Number
| Enter the number or variable to print to the LCD
RAMWrite
RAMWrite
| Modifies the internal memory of the LCD to allow for up to 8 customised characters to be created and stored in the device memory
  - BYTE
Index
| Values 0 to 7
  - BYTE
d0
  - BYTE
d1
  - BYTE
d2
  - BYTE
d3
  - BYTE
d4
  - BYTE
d5
  - BYTE
d6
  - BYTE
d7
ClearLine
ClearLine
| Clears a single line on the display and then moves the cursor to the start of the line to allow you to start populating the line with data.
  - BYTE
Line
| The line to clear, zero being the first (top) line of the display
Cursor
Cursor
| Moves the cursor on the LCD Display
  - BYTE
x
| Set the cursor position in the X plane, 0 is the left most cell
  - BYTE
y
| Set the cursor position in the Y plane, 0 is the top most cell
Command
Command
| Use this method/macro to send a specific command to the LCD. Refer to the Matrix Multimedia EB006 datasheet for a list of supported instructions. For Non-Matrix LCD's refer to the manufacturers datasheet.
  - BYTE
instruction
| Send a defined command to the LCD Screen. See datasheet for supported commands.
PrintFormattedNumber
| Will allow you to print a number up to 32-bits with signed or unsigned formatting. Signed = -2147483648 to 2147483647 Unsigned = 0 to 4294967295
  - ULONG
Number
  - BOOL
Format
| 0=Signed, 1=Unsigned
ScrollDisplay
ScrollDisplay
| Scrolls the display left or right by a number of given positions.
  - BYTE
Position
| Holds the number of positions to shift the display
  - BYTE
Direction
| 0 = left, 1 = right
RawSend
RawSend
| Sends data to the LCD display
  - BYTE
data
| The data byte to send to the LCD
  - BOOL
type
| A boolean to indicate command type: true to write data, false to write a command
PrintFloat
PrintFloat
| Print a Float number rounded up to a specified amount of decimal places.
  - FLOAT
Number
  - BYTE
DecimalPlaces
| Enter how many decimal places to round up to (1 - 6)
RemapCharacter
RemapCharacter
| Assigns a remap character allowing the PrintString function to automatically swap between pre-defined characters.  The characters can be custom (in the range 0-9) or can point to an existing character in the LCD character map.
  - BYTE
RemapIdx
| Remap Index, Range: 0 to (Remap Characters - 1)
  - BYTE
SearchCharacter
| Character to look for a replace
  - BYTE
ReplacementCharacter
| New character value to use in place of the search character.
Start
Start
| Startup routine required by the hardware device. Automatically clears the display after initialising.
Interface mode
| Choose between 4-bit mode, 8-bit mode and 8-bit mode using a port instead of individual pins to improve code efficiency.
Data 0 (11 / 7)
| Data pin 0 - Connects to Data 4 on the hardware in 4-bit mode or Data 0 in 8-bit mode
Data 1 (12 / 8)
| Data pin 1 - Connects to Data 5 on the hardware in 4-bit mode or Data 1 in 8-bit mode
Data 2 (13 / 9)
| Data pin 2 - Connects to Data 6 on the hardware in 4-bit mode or Data 2 in 8-bit mode
Data 3 (14 / 10)
| Data pin 3 - Connects to Data 7 on the hardware in 4-bit mode or Data 3 in 8-bit mode
Register Select (4)
| Register Select Pin - Informs the display if a command or data is about to be sent.
Enable (6)
| Enable pin - Used to synchronise data writes to the display
Use Read/Write Pin
| Set to "true" if the displays R/W pin is not hard wired. Set to "false" if the R/W pin is wired to ground.
Remap Characters
| Used to allow characters to be replaced with alternate characters. Custom characters or characters from the LCD memory map can be used as replacements. Each replacement consumes two bytes of RAM memory and is applied automatically when printing strings.
Display Settings
Rows
| Number of lines of characters the LCD can display.
Columns
| Number of characters the LCD can display on a single line.
Show Background Elements
| Show or hide features like the title and background.
Component Label
Component Label Scale
Text Colour
| Colour of the font characters drawn on the display
Text Background
Display Background
