Author
Matrix Ltd
Version
1.0
Category
Alphanumeric
LCD SPI (MiniClick) component
Generic alphanumeric LCD display based on the standard Hitachi HD44780 controller IC. Connected using an SPI based MCP23S17 SPI IO Expander IC as used on the LCD Mini Click.
Please click here to download the component source project: FC_Comp_Source_LCD_SPI_MiniClick.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_LCD_SPI_MiniClick.fcfx
Clear
Clear
PrintString
PrintString
- STRING
Text
Enter the text or variable to print to the LCD
PrintAscii
PrintAscii
- BYTE
character
Holds an ascii value.
Based on v5 macro, will allow you to print a number. This is limited to a signed-INT, -32768 to 32767
- INT
Number
RAMWrite
RAMWrite
- BYTE
Index
Values 0 to 7
- BYTE
d0
- BYTE
d1
- BYTE
d2
- BYTE
d3
- BYTE
d4
- BYTE
d5
- BYTE
d6
- BYTE
d7
ClearLine
ClearLine
- BYTE
Line
The line to clear, zero being the first (top) line of the display
Cursor
Cursor
- BYTE
x
Set the cursor position in the X plane, 0 is the left most cell
- BYTE
y
Set the cursor position in the Y plane, 0 is the top most cell
Command
Command
- BYTE
instruction
Send a defined command to the LCD Screen. See datasheet for supported commands.
PrintFormattedNumber
- ULONG
Number
- BOOL
Format
0=Signed, 1=Unsigned
ScrollDisplay
ScrollDisplay
- BYTE
Position
Holds the number of positions to shift the display
- BYTE
Direction
0 = left, 1 = right
RawSend
RawSend
Sends data to the LCD display
- BYTE
data
The data byte to send to the LCD
- BOOL
type
A boolean to indicate command type: true to write data, false to write a command
PrintFloat
PrintFloat
- FLOAT
Number
- BYTE
DecimalPlaces
RemapCharacter
RemapCharacter
Assigns a remap character allowing the PrintString function to automatically swap between pre-defined characters. The characters can be custom (in the range 0-9) or can point to an existing character in the LCD character map.
- BYTE
RemapIdx
Remap Index, Range: 0 to (Remap Characters - 1)
- BYTE
SearchCharacter
Character to look for a replace
- BYTE
ReplacementCharacter
New character value to use in place of the search character.
Start
Start
Startup routine required by the hardware device. Automatically clears the display after initialising.
External Address
Selects the value of the three address pins for the MCP23S17.
SPI Channel selector
Prescale
Prescale option selector
MOSI
MISO
CLK
CS
Display Settings
Rows
Number of lines of characters the LCD can display.
Columns
Number of characters the LCD can display on a single line.
Remap Characters
Used to allow characters to be replaced with alternate characters. Custom characters or characters from the LCD memory map can be used as replacements. Each replacement consumes two bytes of RAM memory and is applied automatically when printing strings.
Delay Timings
Delay in microseconds used in the display send function. Most displays will work with the default value of 100us. Some displays may need a slightly longer delay, 166us is known to work well.
Component Label
User Label Text
Text to display
Component Label Scale
Text Colour
Colour of the font characters drawn on the display
Text Background
Colour surrounding the font characters drawn on the display
Display Background
Colour of the background of the display
API
