Component: XML JSON Parser (Runtime Tools)
Jump to navigationJump to search| Author | MatrixTSL |
| Category | Runtime Tools |
- 1 XML JSON Parser component
- 2 Component Source Code
- 3 Detailed description
- 4 Examples
- 5 Macro reference
- 5.1 SetObjectString
- 5.2 GetRootHandle
- 5.3 FindObject
- 5.4 FindObjectString
- 5.5 AddObject
- 5.6 FindNextObject
- 5.7 ParseJSONDataString
- 5.8 GetObjectString
- 5.9 ClearObjects
- 5.10 GetObjectTag
- 5.11 BuildXMLString
- 5.12 DeleteObject
- 5.13 FindNextObjectString
- 5.14 BuildJSONString
- 5.15 SetObjectTag
- 5.16 ParseXMLDataString
- 6 Property reference
A component designed to simplify the collection of data from XML and JSON sources. Parses the raw data and creates a dynamic representation of the data that is easy to navigate and interrogate. Also allows the objects to be manually created or edited and then re-exported as XML or JSON format.
Please click here to download the component source project: FC_Comp_Source_XMLParser.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_XMLParser.fcfx
SetObjectString
| SetObjectString | |
| Sets the data string of an existing object. | |
| Object | |
| Handle to the object | |
| Data | |
GetRootHandle
| GetRootHandle | |
| Allows for user to step through the objects manually using the inbuilt runtime api calls. | |
FindObject
| FindObject | |
| Finds the first instance of an object. Returns the first matching path from the root. Returns 0 if the path was not found. | |
| ObjPath | |
| e.g. "rss.channel.title" | |
FindObjectString
| FindObjectString | |
| Searches for and then collects the data string from the specified path. Returns the first matching path from the root. | |
| ObjPath | |
AddObject
FindNextObject
ParseJSONDataString
GetObjectString
| GetObjectString | |
| Collects the data string from the specified object. | |
| Object | |
ClearObjects
| ClearObjects | |
| Deletes all object data ready for fresh input | |
GetObjectTag
| GetObjectTag | |
| Collects the tag string from the specified object. | |
| Object | |
BuildXMLString
| BuildXMLString | |
| Generate a XML string based on the current objects inside the component. | |
DeleteObject
| DeleteObject | |
| Deletes a selected tag object. | |
| Object | |
| FindNextObjectString | |
| Searches for and then collects the data string from the specified path. Returns the first matching path from the last search | |
| SubObjPath | |
| e.g. "item.title" | |
BuildJSONString
| BuildJSONString | |
| Generate a JSON string based on the current objects inside the component. | |
SetObjectTag
| SetObjectTag | |
| Sets the tag name of an existing object. | |
| Object | |
| Tag | |
ParseXMLDataString
| Properties |
