| Author
Matrix TSL
| Version
1.0
| Category
Utility
Advanced String Functions component
A component designed to add more advanced functions to the existing built-in string library.
Please click here to download the component source project: FC_Comp_Source_AdvancedStringFunctions.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_AdvancedStringFunctions.fcfx
The explode functions use a delimiter to split a string up into an array.
For example "1,2,3,4" using the delimiter ',' would create {1,2,3,4}.
The implode functions do the reverse and create a string from an array.
for example {1,2,3,4} using the delimiter ',' would create "1,2,3,4".
All of the string functions assume that your string variable is large enough to store the data being passed into it. Overflowing the bounds of the string could lead to RAM corruption which could effect the operation of your program.
InsertInto
| Inserts a string into another string at the specified index position.
- STRING
DataString
| Data string to ammend
- STRING
Insert
| Data to insert
- UINT
InsertionIndex
| Index location in the string to insert the data
SearchAndReplace
| Attempts to find a specific string inside the data string and if found replaces with the provided replacement string. Returns the number of times the search pattern was found.
- STRING
StrData
| Data string to scan
- STRING
StrSearch
| String to look for in the data
- STRING
StrReplace
| String to insert into the data
- UINT
ExplodeToByteArray
| Takes an ASCII string and using a delimiter converts it into an array of bytes. Returns the number of values discovered and placed into the DataArray, e.g. "1,2,3,4" would become {1,2,3,4}
- STRING
StringInput
| Data string e.g. "1,2,3,4"
- BYTE
Delimiter
| Delimiting character byte for example ','
- BYTE
DataArray
| Data array to hold the numberic values found
- UINT
MaxCount
| Maximum number of values to return
- UINT
ExplodeToStringArray
| Takes an ASCII string and using a delimiter converts it into an array of strings. Returns the number of values discovered and placed into the DataArray, e.g. "1,2,3,4" would become {"1","2","3","4"}
- STRING
StringInput
- BYTE
Delimiter
- STRING
DataArray
- UINT
MaxCount
- UINT
ImplodeFromByteArray
| Creates an ASCII string from an array of byte values. Places a delimiter in between each value. e.g. {1,2,3,4} would become "1,2,3,4"
- BYTE
DataArray
- UINT
Count
| Number of values held in the array
- BYTE
Delimiter
| Delimiter to add between values
- STRING
Contains
| Scans a string to see if it contains a specific substring. Returns 1 if found, otherwise returns 0.
- STRING
StrData
| Data string to scan
- STRING
StrMatch
- BOOL
RemoveFrom
| Allows a set number of characters to be removed from a starting location in a string.
- STRING
DataString
- UINT
CharsToRemove
| Number of characters to remove from the string
- UINT
StartingIndex
| Index location in the string to delete the data
PositionOf
| Scans a string to see if it contains a specific substring. Returns the location in the string if found, otherwise returns -1.
- STRING
StrData
| Data string to scan
- STRING
StrMatch
- UINT
SearchFrom
| Starting index for the search, default 0.
- INT
ExplodeToINTArray
| Takes an ASCII string and using a delimiter converts it into an array of integers. Returns the number of values discovered and placed into the DataArray, e.g. "1,2,3,4" would become {1,2,3,4}
- STRING
StringInput
- BYTE
Delimiter
- UINT
DataArray
- UINT
MaxCount
- UINT
ImplodeFromStringArray
| Creates an ASCII string from an array of string values. Places a delimiter in between each value. e.g. {"1","2","3","4"} would become "1,2,3,4"
- STRING
DataArray
- UINT
Count
- BYTE
Delimiter
- STRING
ImplodeFromFloatArray
| Creates an ASCII string from an array of float values. Places a delimiter in between each value. e.g. {1.1,2.2,3.3,4.4} would become "1.1,2.2,3.3,4.4"
- FLOAT
DataArray
- UINT
Count
- BYTE
Delimiter
- BYTE
Precision
| Number of decimal points to add to each float value
- STRING
ExplodeToFloatArray
| Takes an ASCII string and using a delimiter converts it into an array of floats Returns the number of values discovered and placed into the DataArray, e.g. "1.1,2.2,3.3,4.4" would become {1.1,2.2,3.3,4.4}
- STRING
StringInput
- BYTE
Delimiter
- FLOAT
DataArray
- UINT
MaxCount
- UINT
ImplodeFromINTArray
| Creates an ASCII string from an array of integer values. Places a delimiter in between each value. e.g. {1,2,3,4} would become "1,2,3,4"
- UINT
DataArray
- UINT
Count
- BYTE
Delimiter
- STRING
