| Author
Matrix Ltd
| Version
1.2
| Category
Misc
Bezel Radiused component
A purely cosmetic component for creating smoothly radiused bezel or frame to fit around other components, or to define the edges of panel sections.
Please click here to download the component source project: FC_Comp_Source_temp/Bezel_Radiused.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_temp/Bezel_Radiused.fcfx
FitInsideBase
FitInsideBase
| Resize and move the bezel so that it fits a given target object. The bezel is fitted within the 'base' of the target - i.e. the face of the object's bounding box with the lowest Z-value.
- HANDLE
Target
| The object to fit the bezel around
FitOutsideBase
FitOutsideBase
| Resize and move the bezel so that it fits around a given target object. The bezel is fitted around the 'base' of the target - i.e. the face of the object's bounding box with the lowest Z-value.
- HANDLE
Target
GetFillPosition
GetFillPosition
| Returns the dimensions and position of a plane area that will fill the frame at its base. The returned position handle could be use, for example, to fit a text box or image within the frame.
- HANDLE
GetLidPosition
GetLidPosition
| Get the position for a plane that will fill the top of the bezel at the highest point of the curve.
- HANDLE
SetColor
SetColor
| A quick way changing the border color without re-calculating the geometry. NB) Does not change the start-up color set using the Properties pane.
- BYTE
Red
| Amount of red in the color. (0...255)
- BYTE
Green
| Amount of green in the color. (0...255)
- BYTE
Blue
| Amount of blue in the color. (0...255)
Thickness
| Sets the thickness of the bezel - radius and depth will change proportionally.
Margin
| This property is used when fitting the bezel to another object using the 'Quick Resize' properties or 'Fit' macros. It sets the distance between the bezel and the fitted object.
Color
| Color of the bezel.
Quick Resize
Fit Outside
| Select an object from this drop down to fit the bezel around the outside of the object's base. Note that this is a 'momentary operation', the bezel will not follow subsequent changes to the target object.
Fit Inside
| Select an object from this drop down to fit the bezel withinf the object's base. Note that this is a 'momentary operation', the bezel will not follow subsequent changes to the target object.
