| Author
Matrix Ltd.
| Version
2.0
| Category
Wireless
Bluetooth (EB024, Generic AT) component
Low level routines for controlling a standard AT Bluetooth interface. Also available in the form of the EB024 Bluetooth E-block.
Please click here to download the component source project: FC_Comp_Source_temp/Bluetooth.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_temp/Bluetooth.fcfx
Making a device discoverable
Example program to set up the Bluetooth module to be discoverable with a pair key. Any data received is then output onto the LCD component. You can connect to the Bluetooth device using a PC with Bluetooth connection and using software such as Flowcode 6, RealTerm or HyperTerminal. Alternatively you can connect using a smart phone running a terminal emulator app or via another embedded Bluetooth board.
Bluetooth Discover
Script 1 contains the AT commands to setup the Bluetooth device to be discoverable with pair key "1234".
Searching for a device
Example program to scan for local discoverable Bluetooth devices. For each device found the MAC address is displayed on to the LCD.
Bluetooth Inquiry
Connecting to a device
Example program to connect to a specific Bluetooth device address and send data to the device.
Bluetooth Connect
The device MAC address is specified using the "CreateCommandString" and "SendCommand" macros.
CreateCommand
CreateCommand
| Adds a single characters to the end of the Command buffer. Returns 1 for success in adding the characters to the buffer. Returns 0 for errors, including Buffer overflow.
- BYTE
Character
| ASCII value or single character,
- BYTE
CreateCommandString
CreateCommandString
| Assigns a string of characters to the Command buffer. Returns 1 for success in adding the characters to the buffer. Returns 0 for errors, including Buffer overflow.
- STRING
Data
- BYTE
| Required to be used whenever the Bluetooth component is used in a program. Initialises the Bluetooth component ready for use.
SendCommand
SendCommand
| Sends the command buffer. Returns 1 for success in sending the command. Returns 0 for errors.
- BYTE
ExpectEcho
| Remote module automatically echos back data: 1 = On (Expect echo), 0 = off
- BYTE
SendCR
| Automatically adds \n to the end of the command data: 1 = append CR, 0 = no CR.
- BYTE
SendScript
SendScript
| Sends Script idx Note that the general property Number of Scripts needs to be set so that it allows the scripts to be accessed and sent. Returns 0 for success and 1 for error
- BYTE
idx
| Refers to the Script page to send (1-4).
- BYTE
Send_byte
Send_byte
- BYTE
ByteVal
StringRead
StringRead
| Returns the ASCII value of character idx of the Response string.
- BYTE
idx
| Needs to be a equal to or less than the string length of the response in order to retrieve a valid character.
- BYTE
StringReceive
StringReceive
| Checks for a response string. Returns the length of the response string if one is present otherwise returns 0.
- BYTE
WaitForResponse
WaitForResponse
| Waits for a response message of type response_code for timeout ms. Returns: 0 for a Response of type response_code 255 (0xFF) for a timeout or invalid response Response string length for any Response not of type response_code
- BYTE
response_code
| 1:OK / 2:ERROR / 3:CONNECT / 4:NO CARRIER / 5:AUDIO / 6:PAIR / 7:RING
- BYTE
timeout
| The timeout value will need to set to allow sufficient time for the response to arrive.
- BYTE
Command Buffer Size
| Maximum number of bytes that can be stored in the outgoing command buffer.
Response Buffer Size
| Maximum number of bytes that can be stored in the incoming response buffer.
Script Count
| Controls how many AT scripts are stored into non-volatile memory
Script 1
| Data to send for script 0, each command should be terminated with a carriage return
| UART Channel selector Software channels are bit banged using generic I/O pins but are not as reliable as hardware channels. Hardware channels use the selected peripheral on-board the target microcontroller.
TX
| Pin to be used for Transmit data
RX
| Pin to be used for Receive data
Use Flow Control
| Flow Control (Handshake) enable or disable. On: Two I/O pins are used to control the flow of data in and out of the device. Off: Flow control is disabled.
Baud Options
| Baud rate option selector
Console Columns
| Number of characters that can be displayed on a single line of the console.
| Selects if the scope traces are automatically added to the data recorder window or not. Simulation - draws an approximation of the UART data onto the scope trace. ICT - sets up the scope trace for incoming data and adds UART packet decoding at the correct BAUD.
Data Source
| Simulation data source used to allow the component to connect to various remote devices Nothing - Simulation data is ignored COM port - Routes the communication data to and from a physical or virtual COM port API - Routes the communication data via a data API component on the Panel.
API
| Selects whichAPI component to route the communication data via. Add API components to the panel before they will be available in this list. API components are available from the Comms component category.
