Component: Control Knob (Controls)
Revision as of 11:59, 3 February 2023 by Wiki bot (talk | contribs)
Version 1.3
Category Controls
Control Knob component
Rotary control designed for SCADA. Has customisable value markings around the control. Simulation only.
Please click here to download the component source project: FC_Comp_Source_temp/ControlKnob.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_temp/ControlKnob.fcfx
GetValue
GetValue
Get the current scale value - this will be the most recent value set using "SetValue", or from the most recent mouse click if the component is in "Control" mode.
- FLOAT Return
SetValue
SetValue
Set the pointer to the given value on the scale. Returns the angle required to point at the given value.
- FLOAT Value
The value on the scale to move the pointer to.
- FLOAT Return
Range
Minimum
The minimum value that the knob will output (fully counter_clockwise)
Maximum
The maximum value that the knob will output (fully clockwise)
Startup State
Sets the initial value when loading the project or when the runtime starts.
Default Value
The default value used on initialise or runtime start.
Title
Show Title
Decides if the component title is shown
Title Colour
Title Label Color
Title Text
Title Label Text
Title Scale
Controls the size of the title text on the panel, default 1.2
Title Offset
Distance above component center to draw the title
Show Label
Decides if a label is shown detailing current setting of the control knob.
Label Colour
Sets the label colour
Label Units
Adds a unit to the end of the label
Label Decimal Points
Number of decinal points to draw on the label
Label Scale
Sets the size of the label on the panel, default 1.0
Label Offset
Distance above component center to draw the label
Numeric Labels
Decimals
How many decimal places to show on the number labels.
Text Size %
Height of the number label text.
Font
Font for the number labels.
Divisions
Number of labelled positions around the knob.
Subdivisions
Number of divisions between the numbered ones.
Scheme
BG Color
Background colour behind the knob labelling - may be transparent.
Positive Color
Colour for number labels which are less than zero.
Negative Color
Colour for number labels which are greater than zero.
Pointer Colour
Buttons
Show Buttons
Controls if the adjustment buttons are shown on the scale arc or not.
Button Color
Color for the component label text.
Adjustment Value
Sets the button adjustment value, will round the value to the nearest whole adjustment. For example with an adjustment of 1,0 the adjustment buttons will jump to the next whole number.
