Component: Dashboard lamp ()
| Author | Matrix |
| Version | 1.1 |
| Category |
Dashboard lamp component
Indicator with bezel and label, particularly suitable for viewing on the dashboard. Indicator on/off colors, bezel color and label all editable via properties.
Please click here to download the component source project: FC_Comp_Source_temp/Dashboard_Indicator.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_temp/Dashboard_Indicator.fcfx
