Component: ADC dial ()
Revision as of 12:03, 3 February 2023 by Wiki bot (talk | contribs)
Author MatrixTSL
Version 1.3
Category
ADC dial component
An ADC component represented by a dial
Please click here to download the component source project: FC_Comp_Source_temp/adc_dial.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_temp/adc_dial.fcfx
Read a 8-bit Byte
Simple ADC example allowing analogue values to be read on ADC inputs AN0 and AN1 as a byte, these are then displayed on the LCD connected to PortB as a number ranging from 0-255 representing 0V to VCC.
FC6 Icon.png ADCByte
Error creating thumbnail: Unable to save thumbnail to destination
Read a 10-bit or 12-bit sample
Simple ADC example allowing analogue values to be read on ADC inputs AN0 and AN1 as a 10 or 12-bit value depending on the target microcontroller, these are then displayed on the LCD connected to PortB as a number ranging from 0-1023 or 0-4095 representing 0V to VCC.
FC6 Icon.png ADCInt
Reading a sample as a Voltage
Simple ADC example allowing analogue Voltages to be read on ADC inputs AN0 and AN1, these are then displayed on the LCD connected to PortB in Volts from 0.0V-VCC. The VRef Voltage property needs to be correct for the Voltage to be calculated correctly.
FC6 Icon.png ADCVoltage
Filtering ADC Inputs
FC6 Icon.png LPFilter
FC6 Icon.png LPFilter2
Analogue Inputs Window
The Analogue inputs window available from the View menu allows you to see the values for all of the analogue inputs which are active in your program. They can also be manually altered by dragging the mouse along one of the sliders.
Chip Diagram
Active analogue inputs are highlighted in yellow on the chip diagram.
Scope Window
Based on the Scope Traces component property.
Settings
VRef voltage
VRef option
Conversion speed
Acquisition cycles
Bit Depth
