API Panel.Position.RotateZ
API contents Rotates the object around the Z axis
HANDLE Handle
HANDLE PivotHandle
- An optional position to treat as the origin to rotate around
FLOAT Degrees
- Number of degrees to rotate by
- Add to a calculation icon: ::Panel.Position.RotateZ(handle, pivothandle, degrees)
