Component: GLCD (SSD1322) Buffered (SSD1322) (Graphical Monochrome)
Revision as of 12:19, 3 February 2023 by Wiki bot (talk | contribs)
Version 1.6
Category Graphical Monochrome
GLCD (SSD1322) Buffered component
Graphical display component based on the SSD1322 monochrome graphical controller IC. Functions without the use of a read pin by hosting the 2K of graphical memory using the microcontroller's RAM memory.
Please click here to download the component source project: FC_Comp_Source_temp/GLCD_SSD1322_buffered.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_temp/GLCD_SSD1322_buffered.fcfx
BPlot
Fc9-comp-macro.png BPlot
Fc9-u16-icon.png - UINT X1
Fc9-u16-icon.png - UINT Y1
ClearDisplay
DrawCircle
Fc9-comp-macro.png DrawCircle
Fc9-u8-icon.png - BYTE Solid
DrawEllipse
DrawLine
Fc9-comp-macro.png DrawLine
Fc9-u16-icon.png - UINT X2
Fc9-u16-icon.png - UINT Y2
DrawRectangle
Fc9-comp-macro.png Initialise
Plot
Fc9-comp-macro.png Plot
Print
Fc9-comp-macro.png Print
Fc9-u8-icon.png - BYTE Font
Fc9-s16-icon.png - INT Number
ReadFontStat
Fc9-u8-icon.png - BYTE Index
0=SpaceWidth, 1=PixelHeight
ReadFontWidth
SetBackgroundColour
Fc9-u8-icon.png - BYTE PixelColour
0=White, 1=Black
SetDisplayOrientation
SetFontScaler
Fc9-u8-icon.png - BYTE ScaleX
Fc9-u8-icon.png - BYTE ScaleY
SetForegroundColour
0=White, 1=Black
SetShadeIntensity
Fc9-comp-macro.png SetShadeIntensity
Allows the shade intensity to be set allowing for up to 15 different greyscale levels. Range: 1-15 Default: 15
Fc9-u8-icon.png - BYTE Shade
Range: 1-15 / 1=Dim / 15 = Bright
Fc9-conn-icon.png Dimensions
Fc9-conn-icon.png Colour
Fc9-conn-icon.png Bit Depth
Fc9-type-14-icon.png Colour Bit Depth
Fc9-type-5-icon.png Chip Select (CS)
Chip select output control pin
Fc9-type-5-icon.png Data (SD)
Serial data output control pin
Fc9-type-5-icon.png Serial Clock (SCK)
Serial clock output control pin
Fc9-type-5-icon.png Reset (RST)
Reset control pin
Fc9-type-16-icon.png Connection Type
Fc9-type-21-icon.png Clock Delay
Number of microseconds to wait after each clock edge. Recommend 1 for faster devices and 0 for slower devices.
Fc9-conn-icon.png Fonts
Fc9-conn-icon.png Font 0
Fc9-conn-icon.png Simulation Mode
Fc9-type-15-icon.png Component Label Scale
Fc9-type-16-icon.png Physical Orientation
