Component: LED (LES, Panel) ()
Author | Matrix Ltd |
Version | 1.3 |
Category |
LED (LES, Panel) component
Panel lamp for a LES bulb. Colour can be changed in component properties.
Please click here to download the component source project: FC_Comp_Source_temp/lamp_les.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_temp/lamp_les.fcfx
