Component: Deinterlace (DSP Operators)
Revision as of 13:09, 7 February 2023 by Wiki bot (talk | contribs)
Version 1.2
Category DSP Operators
Deinterlace component
Allows multiple output buffers to be deinterlaced from a single input buffer. Useful for decoding multiple buffer channels sent via communications or storage.
Please click here to download the component source project: FC_Comp_Source_DSP_Deinterlace.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_DSP_Deinterlace.fcfx
Deinterlace
Deinterlace
Outputs a single value to each of the connected output buffers from the input buffer.
DeinterlaceArray
DeinterlaceArray
Repeats the deinterlace function as many times as set in the data count property.
Connect To
Buffer Size 0
Buffer Type 0
Buffer Size 1
Buffer Type 1
Interlace
Number of Outputs
The number of inputs the multiplexer can switch between.
Data Count
Number of complete output packets the buffer can store. Default 1.
Input Mode
