Exercise - Create an LED Component
- Open a new Flowcode flowchart.
- Make sure that the System Panel is visible. If not, then click on 'View / System Panel'.
- Make sure that Panel Properties are visible. If not, then click on 'View / Panel Properties'.
- Click on the hemisphere in the Shapes menu and drag it onto the Systems Panel.
- Right-click and select 'Center all objects' from the menu.
- Click on the hemisphere to select it. A blue dotted square appears around it.
- Change the name of the component to 'LEDcomponent'. To do this, find the 'handle' of the component, which defaults to 'shape', at the top of the Panel Properties. Click on the name 'shape' and enter 'LEDcomponent' instead.
