Component: DSPBuffer (DSP)
Revision as of 16:34, 17 May 2023 by Wiki bot (talk | contribs)
Category DSP
DSPBuffer component
Creates a DSP buffer to be embedded into a DSP component to hold any output values.
Please click here to download the component source project: FC_Comp_Source_DSP_Buff.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_DSP_Buff.fcfx
Some examples containing the Input ADC component.
On Off Control
PID Control
Prv_GetConsole
Prv_GetConsole
- UINT Idx
- LONG Return
Prv_GetPropStr
Prv_GetPropStr
- UINT Idx
Prv_PutConsole
Prv_PutConsole
- UINT Idx
- LONG Val
Prv_PutPropStr
Prv_PutPropStr
- UINT Idx
- UINT Val
get
get
Embedded - Get/Set uses Type Specified to maintain efficiency Sim - Reverts to long type so 8/16 bit will also fit
- UINT idx
- LONG Return
get_float
get_float
- UINT idx
- FLOAT Return
put
put
- UINT idx
- LONG val
put_float
put_float
- UINT idx
- FLOAT val
Val
Parent Name
Buffer Size
Buffer Type
Data Recorder Trace
Console
Console Size
Text
Orientation
Enabled
